Old 10-26-2011, 02:57 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Default Clutch Fan is OFF!!!
Now that the temps are down from SCORCHING here in Oklahoma, I pulled my mechanical clutch fan off my truck. It took a whopping 15 minutes to do and I only needed a small screwdriver and a BIG crescent wrench. I used the screwdriver to pop the clips out of the lower fan shroud, then to hold the water pump pulley still while i cranked CLOCKWISE on the fan. It wasn't even tight, came off super easy. Dropped the fan out the bottom....I did this solo....and then propped it up against the tire while putting the covers back on. No issues with temps in traffic or sitting, but it is 60 degrees here today.
Definately feels more spirited on the onramps...track night tomorrow to see if I can best myself!!!
Old 10-26-2011, 03:56 PM
ctbourg87's Avatar
ctbourg87 ctbourg87 is offline
Vehicle: 2010 Dodge Ram R/T
Trim Level: R/T
Rep:61
ctbourg87 will become famous soon enough
Good luck at the track!
2010 Ram R/T= de-badged,mc 2/4 drop,dsp,aem cai,mufflex exhaust, edge 3000 stall, 4:10 gears
Old 10-26-2011, 04:26 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Very cool, I've been wanting to do this as well! Do you have stock tstat or 180?
EDIT: Nevermind saw you have 180 in your signature... Did you adjust your fan settings?
Sean
Old 10-26-2011, 04:37 PM
916Timmy's Avatar
Rep:1443
Pics! And I do run a cheapo 180 from AutoZOne...#4128
DSP fan settings are at 186 low 196 high
Old 10-26-2011, 04:57 PM
snrusnak's Avatar
Rep:1385
Thanks for the info. Nice free mod
Sean
Old 10-26-2011, 05:29 PM
moparornocar72's Avatar
Rep:630
I have been thinking about taking mine off, I do haul stuff from time to time, I guess I could always put it back on pretty easy, hmmmmm let us know how the track goes and u just might convince me.
14.268 @ 95 MPH Full Trim
Old 10-26-2011, 05:36 PM
Rep:2616
you could always use a electric pusher fan between the grille & the radiator with a temperature sensitive switch
Old 10-26-2011, 05:54 PM
snrusnak's Avatar
Rep:1385
Well there is still the electric fan. Should provide plenty of cooling...and if you have a tuner you can modify the settings like timmy did...
Sean
Old 10-26-2011, 06:35 PM
916Timmy's Avatar
Rep:1443
I am waiting for a Spal fan or something like that. If it starts getting warm in the spring time, I will put it back on. It literally takes no time at all to do!
Old 10-26-2011, 10:46 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
I ran mine all summer no issues its been off for at least a year now... Good luck the track let us know how you did.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
clutch fan removal
Yet another temp gauge question snookomatic 4.7L PowerTech V8 Specific Topics 6 10-31-2011 10:55 PM
Fan clutch problem mayormolk Newbie Checkin! 7 08-16-2011 07:37 PM
clutch fan not disengaging ddenton Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 1 08-09-2011 09:36 AM
Fan clutch broke off? DodgeAtron Heating & Cooling 1 05-03-2011 01:02 PM
Trouble shooting possible fan clutch issue? moparmanicac Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 3 04-18-2011 07:39 PM
