Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 10-26-2011, 06:43 PM
Chris747 Chris747 is offline
Vehicle: N/A
Rep:33
Chris747 is on a distinguished road
Default Squeaky front end
Im not sure if this is the right section, but i went and test drove a 2001 dodge ram 1500 today. it seemed good, but the front end was squeakin SUPER bad! what would this most likely be? is it a common issue with the dodges?
Old 10-26-2011, 07:58 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
4x4 or 2 wheel? But its probebly bushings.
Old 10-26-2011, 08:00 PM
Vehicle: N/A
Rep:33
its 2 wheel drive. how much would those be to change? is it easy to do your self?
Old 10-26-2011, 10:53 PM
ramfam's Avatar
Trim Level: Base
Rep:21
If it is bushings its not really a do it your self I know the control arms need to come off to replace them but if the price is right and you do dicide to do it replace factory sealed ball joints if it hasn't been done yet. But bushings arnt to expensive. Just time consumeing.
Old 10-27-2011, 08:35 AM
Vehicle: N/A
Rep:33
Ok, I got a question then. Is this simething that may be fixed just by greasing? And If not, if i was to get a small suspension lift, that comes with extended control arms, would that be replacing the parts that are most likely causing the squeak?
BTW I am buying the truck today at 2!
Old 10-27-2011, 11:41 AM
ramfam's Avatar
Trim Level: Base
Rep:21
Yes if you get a kit that has new control arms the bushings should be installed as should serviceable ball joints. Sounds like you want to build a monster. Aut to be cool. Post pic of before, after!
2006 vibration 55mph rake1 Suspension 41 03-07-2014 08:52 PM
2003 Ram Front End Knock over Bumps progressionmotors Suspension 12 11-09-2011 10:05 PM
Front diff locks glhsguy 5.9L V8 Specific Topics 3 02-20-2011 09:50 PM
2007 Big Horn front suspension dee Suspension 1 06-03-2010 05:13 PM
Question about adding Bilstein 5100s (front is sitting lower again) City Slicker Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 17 04-20-2010 10:53 PM
