Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Place your Ad Here!
Old 10-26-2011, 07:42 PM
cody0707 cody0707 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:20
cody0707 is on a distinguished road
Default Power wire
What is the power wire mod I have read about and can it be done on a 2011?
So far: Removed B-pillar tape, Debadged, 15% tint, 55w 6000k HID, 2" leveling kit
Old 10-26-2011, 09:03 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
The "power wire" is where you put a resistor on the intake air temperature sensor and it's supposed to trick the computer to think the intake air temperature is colder than it really is. This is supposed to make the computer dump more fuel and give more power. I highly recommend against using this, it will not give you more power, it will screw up your air/fuel ratios(it is merely tricking a sensor...). Also, at wide open throttle it does nothing as the computer does not use the sensors during open loop...
Sean
Old 10-27-2011, 12:04 PM
carterruss's Avatar
carterruss carterruss is offline
Vehicle: 1994 Dodge Ram 1500
Rep:42
carterruss is on a distinguished road
Air Ram promotes this or at least sells this. Is there no point in using it snrusnak
Current: 1994 Ram 1500 Past: 2002 Ram 1500 Other Ride: 2015 GTI
Old 10-27-2011, 12:15 PM
snrusnak's Avatar
Rep:1388
airram is pretty good but there are a few things on his site that I don't agree with and this is one of them. IMO tricking sensors in an attempt to get more power is not a good idea. It throws off air/fuel ratios, and could be damaging(likely not right away, but over time). This "power wire" will make the computer add more fuel than it's supposed to (due to an overly cold intake air temperature sensor reading) and the air/fuel ratio will be rich. As most performance oriented people know, rich does not give you more power; "lean is mean" Also, under wide open throttle the computer goes into open loop mode(does not use sensors, uses preset fuel and timing maps) so this would do absolutely nothing at full throttle, so in drag racing there would be no effect.
Bottom line is I would not recommend using this product, or any other products like this. The exception to that is the sonnax line pressure booster. I haven't tried it yet, but it is a resistor that has a similar concept, tricks the transmission line pressure sensor, and makes the line pressure increase about 10-20psi if I remember correctly, and this gives more clamping force for the clutches. Many have been using this successfully and I can't think of any ill side effects...
EDIT: And to answer the original question, I don't see any reason why you couldn't do it to your truck, but don't recommend it.
Sean
Old 10-27-2011, 10:26 PM
carterruss's Avatar
Rep:42
Thanks, good info, saved me $50
Old 10-27-2011, 10:29 PM
snrusnak's Avatar
Rep:1388
NP, a good cold intake would be a good mod. It will actually give colder air and a colder intake air temp reading This will give more fuel with denser cold air, a proper a/f ratio
Sean
Old 10-27-2011, 10:31 PM
carterruss's Avatar
Rep:42
Volant powercore is in the mail haha
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 18 06-09-2017 09:33 AM
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
How To: "Big 5" Basic Engine Re-Wiring Upgrade - Tutorial Valldar Dodge Ram Knowledge Base 24 05-24-2014 04:39 PM
Ignition Wire (power wire) DeepWaterHemi Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 05-30-2010 10:07 AM
air ram power wire 4doordodge4life Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 10 04-26-2010 10:37 AM
