Old 12-06-2011, 01:30 AM
BigH0ss's Avatar
BigH0ss BigH0ss is offline
Vehicle: 2013 Ram
Trim Level: Regular Cab 4x4
Color: Maximum Steel
Rep:122
Originally Posted by jwsnowman View Post
Any rubbing with this tire size?
Only rubs on a full turn. And I found the offset it's +20
Old 12-08-2011, 12:22 AM
MoparMike10's Avatar
MoparMike10 MoparMike10 is offline
Trim Level: Lone Star w/ 26L pkg
Color: Brilliant White Clearcoat
Rep:65
MoparMike10 will become famous soon enough
Do these rub at all? If I go with 24s, this is the tire size I'm going to go with. What's the ride like with the 35 series sidewall?
They do rub slightly on the inner fender lining when at full lock and there are some compromises in the ride quality between the wheel/tire size and suspension kit. Potholes are not my friends at all, and I have to be aware of which streets to avoid unless I want to drive them at 25 mph. Personally I wouldn't go with a taller sidewall because it would not look right, the 35 series in that width is a perfect fit between looks and comfort. I don't care for rubber band tires and surely wouldn't want then on a daily driver. The truck does not bounce around or anything but it is a stiffer ride and suspension travel is shorter.
With that being said, the ride is very good. I expected it to be much less comfortable than my previous 20s with 275/45R20 tires and it is almost the same.
I drove my friend's 09 Ram which has the stock 20s and his seems to have a tighter turning radius than mine, if only by a little. I am curious if this is due to my wheels, suspension or if its just in my head? Anyone have an opinion on that?
Audio - Pioneer AVH-P4400BH - PPI Phantom 900.4 and 1000.1 - Boston Pro 60s - Hybrid Audio Legatia L3s - 2x Image Dynamic IDQ10s
Mods - GroundForce 2/3 lowering kit - 24" Color-matched Wheels - K&N Intake - Katzkin Leather Interior
Front is finally lowered!!! 3"/6" drop for only $160 (pics inside) BLACK07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 22 04-26-2011 10:10 PM
2010 Crew Cab small foortprint amp restes Custom Dodge Ram Interior Modifications - Custom Audio / Video 13 04-06-2011 09:45 PM
New to Me 06 Lowered 1500; questions Basher Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 02-22-2011 12:17 PM
Pics lowered on factory 17's? BLACK07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 11 04-24-2010 08:37 PM
Dodge needs a small diesel for the ram series MRRMX Dodge Ram General Discussion 4 10-21-2009 10:42 PM
