Old 10-26-2011, 11:38 PM
1sickram 1sickram is offline
Vehicle: 2012 Ram Express Regular Cab
Color: WHITE
1sickram is on a distinguished road
why the hell dont the just make a 4/6 kit for this truck? they have it for every other truck out there or even a 3/5.
Old 10-26-2011, 11:43 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Don't know man, it is somewhat of a rare rear truck suspension, maybe there simply isn't enough clearance to go that low and have a reasonably comfortable ride and ability to haul/tow...?
I really don't know. I honestly don't like them dropped that low but that's just my opinion. I like leveling the rear, or maybe like a 2/4 at most, but like I said everyone has an opinion...
Sean
Old 10-27-2011, 09:27 AM
Color: WHITE
i wouldnt mind the 2/4 it just doesnt level the truck. i cant stand that raked look. oh well may just have to lift the 2wd. haha
Old 10-27-2011, 09:31 AM
snrusnak's Avatar
Rep:1385
Would you not be happy with a 2" rear drop to level it? You can get a set of RT springs cheap off someone and cut them, or buy the 2" rear drop kit from otto-max pretty inexpensive as well. Just some more ideas...
Sean
Old 10-27-2011, 01:49 PM
Color: WHITE
does the r/t come lowered?
Old 10-27-2011, 02:06 PM
snrusnak's Avatar
Rep:1385
No. It does have different springs though(not sure of the purpose/benefits). I guess it handles a little better? The RT spring and my quad cab spring are damn near the same length. Also, my friends RT sits higher slightly than my quad cab(different wheels/tires but mine are stock size and his are stock size).
Point is the RT has different springs but is not lower...
Sean
Old 10-27-2011, 03:03 PM
11ram256 11ram256 is offline
Vehicle: 2011 Ram
Rep:30
11ram256 is on a distinguished road
I think the problem you get into with going lower than 2/4 with these trucks is the axle to frame clearance in the rear and the issues with the axle shifting to one side or the other when lowering because of the track bar(5 link).
You would probably be fine in the front with the spindles and lowering springs but you would be bottoming out like crazy in the rear at 6" unless you did some kind of notch.
Old 10-27-2011, 08:49 PM
Color: WHITE
i may just rock the 2/4 and throw some 22's on. just debating which would fit and look better 22's or 24's
Old 10-27-2011, 11:09 PM
5.7ram's Avatar
5.7ram 5.7ram is offline
Vehicle: 2010
5.7ram is on a distinguished road
I think if you go with a 2/4 drop , 24' is the way to go.
Also cutting the stock springs or heating the stock springs will cause a bouncy ride.
I think it would be better to cut a lower suspension kit than oem..
Again , not saying it's safe, but thats what i would do.
* Also , if you can wait 1 more week , i will find out next week at Sema with the different suspension company's what the hell is going on with some better drop suspension kits =)
2011 Dodge Ram CC Sport Hemi. / 4300 Hid's Top & Bottom / Tints / 24' Kmc Slide's w Toyo's / BellTech 2/4.
Old 10-28-2011, 03:49 AM
BigH0ss's Avatar
BigH0ss BigH0ss is offline
Vehicle: 2013 Ram
Trim Level: Regular Cab 4x4
Color: Maximum Steel
Rep:122
I have 24's on mine and they rub now so I can't do the 2/4 kit like I wanted. so how do you cut the r/t springs safely? And how can you tell how much to cut?
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 164 12-04-2015 11:58 AM
Comparison highlandchef Total Load Control - Dodge Ram Air Suspension 4 05-30-2012 12:05 AM
Stiffer Springs - Thinking about changing to TRX Springs and Shocks Brute 2009 Dodge Ram Forum 30 01-27-2010 04:20 PM
3/21/10 Coral Springs 14th Annual Special Olympics Car Show BubbaDuss South East 0 01-21-2010 02:52 PM
Wanna Trade your stock for Lowered??? StreetRoyaltyMC Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 01-03-2010 07:58 PM
