Old 10-28-2011, 09:05 AM
1sickram 1sickram is offline
Vehicle: 2012 Ram Express Regular Cab
Color: WHITE
1sickram is on a distinguished road
Originally Posted by BigH0ss View Post
I have 24's on mine and they rub now so I can't do the 2/4 kit like I wanted. so how do you cut the r/t springs safely? And how can you tell how much to cut?
do you have any pics of your truck with the 24's? what are the dimensions of the wheels and what size rubber are you running? thanks
Old 10-28-2011, 02:14 PM
BigH0ss's Avatar
BigH0ss BigH0ss is offline
Vehicle: 2013 Ram
Trim Level: Regular Cab 4x4
Color: Maximum Steel
Rep:122
Here's the truck on 24's. Tires are 305/35/24
Old 10-28-2011, 02:43 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
You can measure the amount of drop you want, and cut a little less than that amount, maybe even half that amount. It's guess and check until you get it right. If you start out cutting too much you can't go back... Cut with a cut off wheel, sawzall, etc... and do so slowly, do not get the spring very hot it will ruin it. Do not use a torch. You should be able to cut to the point where you get a 2" drop safely, any more than that is iffy.
EDIT: Just to reiterate, this is for the rear RT springs only (as far as I know). Not sure if any other versions of the springs have the tight coils at the top. I have been thinking of doing this on my truck this weekend, we will see how much extra time I have sunday...
Sean
Old 10-28-2011, 04:51 PM
BigH0ss's Avatar
Vehicle: 2013 Ram
Rep:122
What I mean is do i measure 2" around the coil or do I hold the coil vertically an measure up across the length of the coils?
Old 10-28-2011, 04:55 PM
snrusnak's Avatar
Rep:1385
Measure vertically along the length of the coil, like perpendicular to the coils. If you measure 2" and cut it there, you will get more than a 2" drop. If you want a 2" drop, start with a cut at 1", and use your judgement to keep working at the desired finish result. Guess and check, you may end up making several cuts but at least the springs are extremely easy to take out and reinstall, only about a 30 minute job total.
If you want give me a call I can better explain it verbally lol. PM me if you want I'll give you my number.
Sean
Old 10-28-2011, 05:04 PM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
I wouldn't cut the springs- get a lowering kit. Do it right.
When I worked for Stillen, we took a tour of the Eibach facility. Lots of engineering goes into both stock and aftermarket springs, and you can majorly compromise your suspension by cutting your springs.
Old 10-28-2011, 09:06 PM
Color: WHITE
looks great, thats not lowered is it?
Old 10-28-2011, 09:55 PM
fundaddy75's Avatar
fundaddy75 fundaddy75 is offline
Vehicle: 2004, SLT, 3500 HD Tow Pack.
Trim Level: Slt Auto Cloth.
Rep:13
fundaddy75 is on a distinguished road
I use to do some very custom rides and most of my customers wanted what no one else had. These guys were my spring solution 99% of the time. Send them the stock springs and they will send back the stock springs and another perfectly calibrated set. Sometimes they already have the specs for your truck so they will not need your spring. I always sent the spring to be sure the lowering springs were perfect. Great for any type of spring change you want.
Cost? Well they were usually close to the same cost as a off the shelf set. It all depends on the spring. Great people to work with. Oh yeah, and they are made in the USA by Americans.
http://www.coilsprings.com/
Just happy to be playing.
Old 10-29-2011, 01:05 AM
BigH0ss's Avatar
Vehicle: 2013 Ram
Rep:122
No it's not lowered and shoot me a pm w ur number I'll call ya tomorrow.
Old 10-29-2011, 01:07 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I've cut a few of my coils with no ill effects...stock as well as 2" drop coils...I trimmed then to get the exact look I wanted. I would cut an 1/8th coil at a time..i think i did 1/4 coil at the most on any coil i've done.
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Comparison highlandchef Total Load Control - Dodge Ram Air Suspension 4 05-29-2012 11:05 PM
Stiffer Springs - Thinking about changing to TRX Springs and Shocks Brute 2009 Dodge Ram Forum 30 01-27-2010 03:20 PM
3/21/10 Coral Springs 14th Annual Special Olympics Car Show BubbaDuss South East 0 01-21-2010 01:52 PM
Wanna Trade your stock for Lowered??? StreetRoyaltyMC Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 01-03-2010 06:58 PM
