Old 10-27-2011, 06:34 AM
Josh95Ram Josh95Ram is offline
Vehicle: 1995 Dodge Ram 1500
Color: Dark green
Josh95Ram is on a distinguished road
Default Oil fill tube
I have a 95 1500 with a 5.9L and before i bought the truck I found out that someone had broken off the dipstick inside the tube. Can anyone tell me how to take the oil fill tube out so I can get the old dipstick out? Its one of the pressed in kind.
Old 10-27-2011, 08:29 AM
Welcome to the forum!
If it's a press in, you should be able to twist it and rock it back and forth to get it out. A little heat on the block casting there will help but be careful. Don't set things on fire!
Old 10-27-2011, 12:27 PM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
take a small drill bit to plastic handle in the tube,drill a hole in it at an angle and see if you can get a pair of needle nose pliers to grab it. if you start twisting and pulling on the dipstick tube you got a change of breakin it off at the block, then your really screwed
Old 10-28-2011, 01:55 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
OK, someones gonna tell me off here, I suppose, but I'll let you in on my little secret fix, I went around the tube with a tubing cutter, below where I figured where it was broke, once removed, I got a pice of stiff hose, about 2" long, slipped it over the ends of the cut tube, and I swear, no one will ever know the difference, if you want it to show, and extra stiff, put a coupla heavy zipties or a hose clamp over the repair, I didn't, and it is just fine. Now, to fix the dipstick... find a blown up motor, I would think, Any blown up motor. Vans are extra long, cut off the excess, and make your own marks, using a hammer and a chisel or punch or something!!!
Old 10-28-2011, 02:15 AM
Rep:2657
channel lock pliers should do it too
Oil fill plug on rear diff Bert66 Oil Change 23 07-14-2012 11:56 PM
broken oil dipstick tube SOTASFINEST65 5.2L V8 Specific Topics 8 07-03-2011 07:07 PM
2005 5.9L oil blowing out of valve cover tube Rammit Cummins Diesel Specific Topics 3 05-14-2011 10:59 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 10:38 AM
