Stuck in Limp Mode until completely warmed up - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 10-27-2011, 10:58 AM
tat2dwt tat2dwt is offline
Vehicle: 2001
Color: Burgandy
tat2dwt is on a distinguished road
Default Stuck in Limp Mode until completely warmed up
I have a 01 3500 5.9 diesel stock engine with intake a 4" exhust. This just started happening. After I wait for start light to go out and start engine I have to wait until the needle comes off peg to drive with power. If I don't wait the truck has no power until it warms up and it's like a switch is thrown and power is restored. Then the truck will drive all day with no power issues. The only code I'm getting is a P 1693 which is a companion code I believe? This has been going on for a couple of weeks. I did change the fuel filter resently.
Old 10-27-2011, 12:29 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
"P1693: DTC Detected In ECM Or PCM"
"P1693 is the companion code...it means that there may be another code stored and you need to use a OBDII scanner to extract it.
If I was a betting man I bet it will be P0216....Injection Pump timing failure...
Let us know what happens."
You need to go to autozone and have them pull the codes for you(they will do it for free). Word of caution, take their advice with a grain of salt, get the actual codes that appears on the scanner, not their diagnosis. Post the codes here and we may be able to help you diagnose it.
Sean
Old 08-15-2014, 09:02 AM
ng7997 ng7997 is offline
Vehicle: 2000 Dodge Ram 2500
ng7997 is on a distinguished road
Default Limp mode untill warmed up
I have the same exact symtoms with my truck. Havent been able to figure out whats causing it. Did you make any head way with your issue?
ETC light and LIMP MODE mike333h 5.7L V8 Specific Topics 3 09-17-2011 09:53 PM
Truck stuck in Manual Shift Mode - Anyone Else? moose3 2011 Dodge Ram Forum 11 08-08-2011 09:03 PM
limp mode no codes... Mano94 V6 Specific Topics 1 02-18-2011 05:32 PM
Limp Mode toddler 5.7L V8 Specific Topics 0 03-12-2009 02:03 PM
