Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 10-29-2011, 08:41 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
ngk 4306 coppers will last a long while...I rarely spray and dont go to track much (every 2-3 months)...I don't see any performance difference running them all the time..also run a colder tstat as well (most do 180, I'm at 170)
Old 10-29-2011, 09:12 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 Dodge Ram SRT10 RC 6spd
Trim Level: SRT10 RC
Color: Brilliant black
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
What power rating are the NGK4306's good to?
Traded in[SIGPIC]2004 SRT10 RC in black, with 500+HP, B&G Stage2 PCM, K&N drop in, JMB Catless mids, JTSVP Gen1 shifter, all synthetic fluids, lots of underhood billet with a Snakeskin radiator cover from JTSHydro, LED tails, BedRug, colormatched tonneau!!!!!!!! Upgraded!!!!!!!!
Old 10-29-2011, 09:57 PM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
Thanks guys. I look into plugs too then. Is the part number the same for the 4G Hemis as it is for you 05?
2013 F-150 King Ranch 4wd 5.0
Old 11-13-2011, 04:48 PM
RandTx RandTx is offline
Vehicle: 2006 Dodge Ram
RandTx is on a distinguished road
I think you would be OK with a 75 shot.
I've had a couple of friends blow up their new gen hemi's on spray but they were both ruining diablo predator custom tuning and running a 100-125 shot
Stock tune would have less wot timing to start with so to a degree it would be safer.
I'd still go with a 170-180 thermostat, the NGK plugs run premium gas, and not try to spray right out of the hole let it build up at least 3500 rpm as an extra margin of safety
Old 12-23-2011, 10:06 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
What is a good throttle body plate setup? With the new Vararam on, I don't a good place to drill a nozzle. I guess 6-18 inches away from the blade is best, all I have room for now is on the silicone coupler
Old 12-23-2011, 10:39 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I don't know about your question Timmy....
But to the OP: I'm not an expert with nitrous but I believe if you run higher octane with the nitrous it should be ok. Higher octane will give you a little more protection and is sort of the same thing as retarding the timing (in a round about way) as it will burn slower. For example you could run 91 or 93 octane when you spray and this should give you more protection.
Sean
Old 12-23-2011, 03:46 PM
I'm not sure with the vararam. the HSW plate is about an inch thick so it would move the TB forward by that much. Think most are about the same thickness. If that's an issue you might be able to trim the elbow shorter??
Think Fred or somebody is running a vararam and said they installed a wet fogger in the elbow rather than a plate system.
Old 12-23-2011, 03:50 PM
916Timmy's Avatar
Rep:1443
It would be really easy to adjust the height of the Vararam....It would be up, not forward
Old 12-23-2011, 04:14 PM
Oh it never clicked you were talking 4th gen. think the plate would just raise the height of the TB so you would just shorten the tube. and I suspect the plate would work better on that truck manifold or a car manifold since they have more internal space (aka distance to valves)
but.
after seening a couple a couple of local guys crater the newer motors in person with 100-125 shots I'm not keen on the idea of spraying the newer hemi. Of course both those guys were in cars and on diablow custom tunes so it might be safer on stock tune.. or not, if it has somethign more to do with the varraiable cam timing. Either way you if go nitrous take it slow and start of with smaller shots
Old 12-23-2011, 04:35 PM
916Timmy's Avatar
Rep:1443
Okay.....VA4Meds is running 100 on his crew cab, I'll have to ask him how his is set up, but he is almost stock with just nos running a 13.4
diablo cmr custom tune crusher 2009 Dodge Ram Forum 5 10-23-2011 11:40 PM
Predator question... 87 tune on 87 fuel vs 91 tune (modded) to run on 89 fuel limitlessent Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 7 04-23-2011 01:09 AM
