Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Dodge Ram Decals
Old 10-28-2011, 05:41 AM
ceconant ceconant is offline
Vehicle: 2006 Dodge Ram
Rep:21
ceconant is on a distinguished road
Default 545-RFE shift kits
so i have a 06 ram 1500 with a 545-RFE, with a line pressure booster and i was plaining on a diablo trinity. my question is has any body ever put a trans go shift can in this transmison with any of this other mod
Old 10-28-2011, 09:37 AM
mgh's Avatar
mgh mgh is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
I am running the shift kit, Sonnax, and Diablo with no problem.
Old 10-28-2011, 10:11 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I have the Diablo and the Sonnax....I will do the trans go when I do the tq converter swap!
Old 10-28-2011, 09:37 PM
Rep:21
thanks that going to be my next mod
Old 10-28-2011, 10:36 PM
Rep:3322
I'm in the same boat as Timmy, Sonax, and trinity right now, and the TransGo is in the garage waiting for me to do the t-verter this winter.
Old 10-29-2011, 12:02 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I also have a diablo, sonnex and shift kit... you'd be better off doin a shift kit and tq vertor on separate days...tq vertor you don't need to drop the pan and the shift kit you do... shift kit took me about an hour to do (with air tools)
Old 10-29-2011, 12:13 AM
916Timmy's Avatar
Rep:1443
Thanks for the tip Freddie!!!
Old 10-29-2011, 12:44 AM
chefred112's Avatar
Rep:656
I did 3 shift kits the last couple weekends and swapped a tq vertor (to stock) on mine just before that..ooo, and installed my tranny temp guage at the same time..
Old 10-29-2011, 08:04 AM
mgh's Avatar
mgh mgh is offline
Rep:27
When you install the shift kits, are you doing the pump upgrade also, or just the valve body??
Old 10-31-2011, 09:45 PM
Rep:21
so i order the shift kit, i was told that we would you have to remove the one way check vavle before you do this. also you have to put a biger trans mission cooler. i planed on only puting a deeper trans pan on it a month after i put this kit in this week end. i need to know if this well work before i brake this tranmission apart thanks
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 12:23 AM
towing 4 down behind mh rainhater1 Towing 15 09-21-2010 11:12 PM
Transmission will not shift stmabe 5.9L V8 Specific Topics 9 07-16-2010 06:52 AM
Axle actuator! kicknjeep Suspension 5 03-08-2010 02:10 PM
