Old 10-31-2011, 11:35 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
Originally Posted by mgh View Post
When you install the shift kits, are you doing the pump upgrade also, or just the valve body??
just the springs and little valve..what pump upgrade are you talking about? the only other stuff i see in the box was a resistor and a new snap ring..
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 10-31-2011, 11:43 PM
chefred112's Avatar
Rep:656
Originally Posted by ceconant View Post
so i order the shift kit, i was told that we would you have to remove the one way check vavle before you do this. also you have to put a biger trans mission cooler. i planed on only puting a deeper trans pan on it a month after i put this kit in this week end. i need to know if this well work before i brake this tranmission apart thanks
that's the check valve in the valve body right?..all you're doing is dropping pan, disconnect connect/harness from the top...unscrewing pan filter, unscrew valve body and remove...should only be replacing a check valve and some springs and little rings on the pistons...
Old 10-31-2011, 11:48 PM
ceconant ceconant is offline
Vehicle: 2006 Dodge Ram
Rep:21
ceconant is on a distinguished road
the one i was about was a one way check valve in the transmission cooling lines. im not sure if there is even true or not i was told that he burn his transmission up becouce it wanst removed. aslo this was on a desiel truck
Old 10-31-2011, 11:50 PM
chefred112's Avatar
Rep:656
..and don't forget the new cover plate for the springs...
Old 10-31-2011, 11:53 PM
chefred112's Avatar
Rep:656
o ok...diesels have a different tranny 68rfe and their shift kit is a little different
Old 11-02-2011, 07:43 PM
Rep:21
do anybody know of any good write ups on put a shift kit in
Old 11-03-2011, 02:02 PM
XC450's Avatar
XC450 XC450 is offline
Vehicle: 2006 QC Hemi Ram
Trim Level: Lone Star
Rep:37
XC450 is on a distinguished road
Would like to see a write up as well.
2006 Ram Hemi QC - HemiFever - DiabloSport Predator - Jet 180 T stat - K&N cold air - Pacesetter LTs & Y-Pipe - Flowmaster Hushpower - 5" side exit - 6" lift - 35x12.5x20 Toyo MT - 20x10-24 Fuel Hostage - Summit Racing Drilled & Slotted Rotors - Ceramic Pads
Old 11-07-2011, 09:00 PM
mgh's Avatar
mgh mgh is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
The full "re-program" kit comes with a bigger spring for the bypass flap in the pump. In order to install that, you have to drop the trans. When you replace that spring, you can hold higher line pressure.
Old 11-08-2011, 12:13 AM
chefred112's Avatar
Rep:656
I'll have to check to see if my kit was a full reprogram kit...I've done quite a few so i don't even read the directions anymore..just look at the pictures...
Old 11-08-2011, 09:19 AM
Rep:21
the kit i got u have to pull the tc out and geta puller for the pump. the dirictions make the hole kit look esay. im just waiting to get my deeper pan and another trans cooler.
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 01:23 AM
towing 4 down behind mh rainhater1 Towing 15 09-22-2010 12:12 AM
Transmission will not shift stmabe 5.9L V8 Specific Topics 9 07-16-2010 07:52 AM
Axle actuator! kicknjeep Suspension 5 03-08-2010 02:10 PM
