New tire losing pressure because of rim - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-28-2011, 02:39 PM
CanadianCat CanadianCat is offline
Vehicle: 2003 Dodge Ram Hemi SLT 4x4
Color: Grey
CanadianCat is on a distinguished road
Default New tire losing pressure because of rim
Hi there,
Last month I purchased a 2003 Ram 1500 SLT 4x4 Hemi and am happy with my purchase but I have a rim problem that I would like to discuss. My rims are the 17" (5 bolt) alloys.
The truck had new tires (P rated) and I knew I would have to get a set of LT tires anyways. I noticed one tire was losing pressure, it would be down to about 20 psi from 32 after a couple weeks. I figured it was because the tire wasn't fitted on the rim correctly or it had a hole or it was because it wasn't an LT tire and wasn't suitable. So i got a good set of LT tires put on and the new tire on the same rim was losing pressure at the same rate as well. That pretty much narrows it down to the rim being the problem I assume.
Is there a way of fixing the rim somehow or is it in my best interest to get a new rim? Thanks for reading and I appreciate any feedback.
Old 10-28-2011, 02:58 PM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
Have to ask- has the valve stem been replaced?
Old 10-28-2011, 03:00 PM
Daytona1445's Avatar
Daytona1445 Daytona1445 is offline
Vehicle: 2005 Dodge Ram
Trim Level: Daytona
Color: GoMango
Rep:12
Daytona1445 is on a distinguished road
Assuming that the rubber valve stems where changed with each tire replacement that does narrrow it down to the rim. The options are to replace that rim or get it fixed assuming you can find the leak in it. Fixing it may cost more than a replacement would.
Old 10-28-2011, 03:10 PM
letsjet's Avatar
letsjet letsjet is offline
Vehicle: 2014 Ram 1500 Express 5.7L 4x4
Trim Level: EXPRESS
Color: FLAME RED
Rep:45
letsjet is on a distinguished road
It's common to have corrosion happen around the bead. You can sand it off and apply a type of bead sealant there and build it up with a few coats. Make sure the stem is good and not leaking. A dunk tank won't find a real slow leak unless you put in 70+ lbs of air.
2014 Ram 1500 "Sport"Express 5.7L Quad Cab 4 X 4 Flame Red
2010 Dodge Challenger R/T Furious Fuchsia 6 speed
2016 Jeep Rubicon 4 X 4 Firecracker Red
2017 Z51 Corvette Stingray
Old 10-28-2011, 06:37 PM
If it is the rim (and I like those ^^^^ suggestions to narrow it down), then the rim is cracked somewhere, which means you should replace it.
Old 10-28-2011, 07:21 PM
Stainless's Avatar
Stainless Stainless is offline
Vehicle: 2011 Dodge Ram
Color: Bright white
Rep:13
Stainless is on a distinguished road
Take a soapy solution in a spray bottle and spray where the rim and tire bead meets, its it starts bubbling really bad its corrosion on the rim and will need to be sanded off, thats what im expecting considering your from the east coast.
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Low tire pressure warning on EVIC Razorbass 2011 Dodge Ram Forum 17 09-17-2011 02:33 PM
LT tire pressure? euromade Dodge Ram Wheels And Tires 3 08-22-2011 10:58 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Tire pressure monitor 2010Ramowner 2010 Dodge Ram Forum 3 04-30-2010 12:41 PM
