Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Place your Ad Here!
Old 10-28-2011, 05:16 PM
mntnclmbr mntnclmbr is offline
Vehicle: 2006 Dodge Ram
mntnclmbr is on a distinguished road
Default ABS, Brake and enigine light on
Ok here we go, I've been working on this problem for sometime now...I've read through many of the threads on this sensor issue and tried them all. Soooooo, here's my issue and then I'll tell what i tried. Set the parking brake one evening, next morning I released it and drove out of the drive about 50 yards down the street the ABS, brake and engine lite came on...seemed to be running fine so I did my thing then came home, parked it popped the hood and started looking around. Had a friend pull the code (speed sensor) so replaced it on the rear end (no change) then replaced the one on the transmission (no change) - each time I cleared the code by pulling the battery cable off for a awhile (30 mins or so). Along with the light issues I also found that my overhead info center and odometer, speedometer, 4 wheel drive cruise control and I'm sure there's more aren't operating correctly or at all....Anyone figure this out yet? I'm no stranger to Dodges, but this has me on the verge of trading it off...Any suggestions would be great, Thanks
Old 10-31-2011, 08:43 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
What was a actual code # that you got from it?
Also, have you read the code(s) since that first time?
brad
Interested in one of my mods?
Old 11-02-2011, 12:13 AM
hey Brad12kx, Off the top of my head I'm not sure we had them written down though...Something odd though, I spent most of that day that I had written the post on reading alittle deeper into some of the others similar...Later on I went out to the truck and pulled fuses 35 - 38 or 39 and checked them - ironically, all the lights went out, cleared the engine light code while they were out, I checked voltage meter and they were dead or almost dead. I cleaned the terminals and then reset the fuses. NOTHING CAME BACK ON, everything is running fine, cruise, info center, 4wheel drv, and everything else. Soooooo, what did I do to make this worker? I don't know? Again, It goes back to being a Dodge
Old 11-02-2011, 01:14 AM
brad12kx's Avatar
Rep:2581
Fuse 35 feeds the cluster
Fuse 36 feeds the Stereo amplifier
Fuse 37.....No fuse 37
Fuse 38 feeds the power outlet on the dash
Fuse 39 feeds the seat belt tensioner and subwoofer amp if applicable.
I figure fuse 35 was the culprit. It likely benefited from you removing and re-inserting it. If the power was un-stable through this fuse, al kinds of weird things could happen, and most of them instrument cluster related.
Good work! I think you nailed it.
brad
