Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Electrical
Old 10-29-2011, 01:09 PM
hymnatr hymnatr is offline
Vehicle: 2011 dodge ram 1500 sport crew
Color: Metallica Black
hymnatr is on a distinguished road
Default Heated Steering Wheel Problem
I've had my truck since April and have only had to use the heated steering wheel a couple of times. It's starting to get colder here and all of the sudden it's not working anymore. I turn it on, the light turns on, I hear it click and then it turns off. If I try and turn it on again the light turns on and off after about 5 seconds. It's 50 degrees right now and when it was working it was warmer out.
Any help or ideas?
Thanks
Old 11-02-2011, 11:52 PM
No one has any ideas?
Old 11-03-2011, 12:16 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Any chance you have the AC button pushed?
brad
Interested in one of my mods?
Old 11-03-2011, 03:17 AM
mrcivic's Avatar
mrcivic mrcivic is offline
Vehicle: 2011 Dodge Ram Crew Laramie
Color: Mineral Gray Metallic
mrcivic is on a distinguished road
Brad might have something there, it could be something simple might be worth a read in the owners manual if you haven't already done that. If you have it should be worth a trip to the dealer, maybe a faulty relay or something.
Good luck.
Old 11-05-2011, 11:03 AM
I did read the manual and the only thing it said was that it might be to warm, well it was 44 this morning. As far as the a/c goes i had the heaters and the seat warmers on and it still didn't work. Was tring to not go to the dealership and hope it was something simple but I guess I'm going to have to.
Old 11-05-2011, 01:36 PM
brad12kx's Avatar
Rep:2581
Unfortunately, it looks that way. There is everything from the control module to the clock spring to the heating element itself. Hopefully the dealer will tell you what the actual problem was. It would good information to have for the future if there is a 'common' point of failure that can be passed on to members in the years to come.
Keep us posted.
brad
Old 01-23-2012, 10:07 PM
Mikecadt Mikecadt is offline
Vehicle: 2009 Dodge Ram
Mikecadt is on a distinguished road
Brad,
Just wondering if you ever got your heated steering wheel issue resolved. I have an 09 and just started to have the same exact problem. It was working last week, went to turn it on this morning(34 degrees out in VA) and the light would come for about 2 secs and go back out. Fuse 36 looks to be the fuse for it and it was fine.
Let me know . Thanks
Old 01-23-2012, 11:15 PM
Troy. Troy. is offline
Vehicle: 2011 Ram
Trim Level: Sport CC 4x4
Color: Bright silver metallic
Troy. is on a distinguished road
I actually had this problem one night last week, it was about -40*C so naturally I used the remote starter to start the truck. (heated seats and steering wheel come on automatically at a certain temp. as you know) I can't remember if I had started it twice or not from the remote, but anywho, I jumped in and the steering wheel was ice cold, tried the button and got the same results described above... Gave me a sick feeling thinking that I'd have to take my baby into the dealer. Needless to say, I shut the truck off and restarted it, worked fine since then. I don't normally use the heated steering wheel except for the first little bit of driving, then shut it off.
Not sure if this is a temperature related issue or what?
Old 01-24-2012, 02:11 AM
brad12kx's Avatar
Rep:2581
Wasn't mine with the problem, but rather hymnatr. He hasn't posted on the forum since his last post here. Would like to know what the dealer did to repair his.
brad
Old 01-24-2012, 01:07 PM
rcgreg rcgreg is offline
Vehicle: 2012 Longhorn
Trim Level: longhorn
Color: Black/gold trim
rcgreg is on a distinguished road
Hmmm, it sounds as if there is a short in the heating element, causing the breaker to trip after a few seconds, Then the breaker resets itself.
I'm afraid a trip to the dealer is needed to be sure - could be a sensor problem also - but you need to be able to query the computer codes to see. Have you checked your EVIC to see if there are any messages on it? Not sure if the system would do that - but it would be a nice feature if it did.
Swapping Infinity head units, & steering wheel audio controls Danstona Custom Dodge Ram Interior Modifications - Custom Audio / Video 12 02-21-2013 09:42 PM
Steering wheel Qúestion ccga3359 Dodge Ram General Discussion 4 04-22-2011 10:52 PM
built in steering wheel controls Skillets Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 04-16-2011 02:25 PM
4 Wheel Drive problem...I think!?! zxtuner85 5.7L V8 Specific Topics 5 12-16-2010 07:50 AM
Steering problem?? patrickh Suspension 2 02-12-2010 10:09 PM
