Heated Steering Wheel Problem - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Electrical
Old 02-02-2012, 04:04 PM
RedneckRemedy85 RedneckRemedy85 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: CC Sport w/Rambox
RedneckRemedy85 is on a distinguished road
I also experienced this problem, but it only happened once. I remember my heart sank when the light would not stay on, but I restarted the truck and its been good ever since. Now I just keep my fingers crossed.
Old 02-02-2012, 04:05 PM
Perhaps try disconnecting the battery and resetting the system, I dunno, just a thought.
Old 10-22-2012, 11:02 AM
mk3barti mk3barti is offline
Vehicle: 2011 Sport
Color: Black Pearlcoat
mk3barti is on a distinguished road
Back from the bottom. Does anyone know if there was resolution to this issue? My truck did the same thing this morning.
Old 10-22-2012, 10:38 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Unfortunately, the very members we were hoping to hear back from as to what the final outcome was, have not been back to provide that information.
I do not believe there is any common failure issue as there is very little discussion about this and many have found that resetting the system by either restarting the truck or disconnecting the battery cable has correct their issue.
brad
Interested in one of my mods?
Old 10-22-2012, 11:19 PM
Vehicle: 2011 Sport
I called the dealer and they claimed that it runs on a sensor and will not turn on after a certain cabin temperature. This was after I asked if it ran on a sensor so I am not sure if I gave them the idea or not. Either way it worked after shutting off the truck but then repeated it again. Seems to occur after heating for awhile, turning it off and then trying to turn it on again right away.
Old 10-22-2012, 11:54 PM
brad12kx's Avatar
Rep:2581
I think for the most part, the temperature is not cold enough.....yet. LOL
Us humans think it's cold, but by February we will think this temperature is hot.
brad
Old 10-23-2012, 12:40 AM
Vehicle: 2011 Sport
I was thinking the same thing....I am so not ready for winter. 10 cm coming here tomorrow....
Old 10-25-2012, 11:45 AM
HEMISRGN HEMISRGN is offline
Vehicle: 2012 RAM
Trim Level: LARAMIE
Color: RED
HEMISRGN is on a distinguished road
Anyone know for certain how this is supposed to actually work.... mine comes on normally when I get in and then seems to "cool" off even though the light is still on. Is it supposed to stay "hot" like the seats do or does it run one cycle of heat and then automatically shut off? When I shut it off for a few seconds and then restart it, it seems to heat back up but it doesn't seem to stay "hot" for extended driving ie won't stay hot for the entire work-home commute. Of note, no issues with the seats staying hot. FYI mine is a new Laramie with <1000 miles
Any thoughts on this... Thanks!! Or point me to another thread,etc.
Old 10-25-2012, 02:43 PM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
This is from Chrysler.... not that it helps much....
The heated steering wheel has two selectable settings, ON and OFF. The heated steering wheel only operates with the vehicle’s ignition is in the RUN position, and will always stay in the OFF setting unless the heated seat switch is pressed. Once the switch is pressed the Light Emitting Diode (LED) on the face of the switch will illuminate, indicating that the heating element in the steering wheel is operating. Pressing the switch while the heated steering wheel is on, will turn the heating steering wheel and the LED on the switch off.
Normal heating of the steering wheel will last a minimum of 52 minutes, unless the switch is pressed or a system fault has been set. Heating of the element is controlled by the Heated Seat Module (HSM), also know as the Comfort Seat Wheel Module (CSWM), and a temperature sensor integrated into the steering wheel heating element. The integrated temperature sensor relays the temperature of the steering wheel to the HSM, and adjusts the internal heat setting accordingly.
The Heated steering wheel will automatically shut off if the heating element reaches a temperature greater than 50 degrees Celsius (122 degrees Fahrenheit).
Old 10-27-2012, 09:44 AM
Vehicle: 2012 RAM
Trim Level: LARAMIE
Color: RED
Thanks for that, I'm going to get an oil change next week just because I want to change the oil that sat in the truck on the lot. I will bring this up at the dealer and then repost their comments.... hopefully can post some followup by late next week.
Swapping Infinity head units, & steering wheel audio controls Danstona Custom Dodge Ram Interior Modifications - Custom Audio / Video 12 02-21-2013 09:42 PM
Steering wheel Qúestion ccga3359 LD RAM - General Discussion 4 04-22-2011 09:52 PM
built in steering wheel controls Skillets Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 04-16-2011 01:25 PM
4 Wheel Drive problem...I think!?! zxtuner85 5.7L V8 Specific Topics 5 12-16-2010 07:50 AM
Steering problem?? patrickh Suspension 2 02-12-2010 10:09 PM
