Old 10-29-2011, 01:57 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Default KORE High-angle CV Joints
It is my sole and humble opinion with regards to "vibration" or "shuddering" problems that some are experiencing are pretty much directly related to CV joint angle after levelling kit installs. I found this ad for "KORE" on Ready-lift's webpage along with their full support of the problems with the OEM flaw with this issue on the 09' and newer rams. Although kind of pricey, I would think one would be problem free right from the get-go installing high-angle cv joints along with your choice of levelling kit, they are $800 bucks, but I am betting they would be worth every penny. I know now your upwards to a $1000 bucks, but if all your after is having a trouble-free levelled truck, this could be the answer. Correct me if I'm wrong.
Old 10-29-2011, 09:11 PM
novaken's Avatar
novaken novaken is offline
Vehicle: 2011 Ram 1500
novaken is on a distinguished road
I also agree...do it right or do it twice. Luckily, I have no vibrations after installing my lift. Still may do this after warranty is up.
Old 10-29-2011, 09:34 PM
I push the skinny pedal
Rep:3277
The KORE h-a CVs are a high quality product, I've been looking at them very hard to take my dropped 4x4 closer to mother earth, as I'm seeing similar angles, just in the opposite direction as a mildly lifted/leveled truck.
I don't however know if they would be a suitable option for curing a vibration from a level as the stock CVs can handle 15 degrees regularly before having problems. But if you've exhausted all other possibilities for vibration, then by all means give it a try. Even if it doesn't cure the problem, you've got a bullet proof set of CVs on there now.
Kurtis
P1128 p1129 firecadet613 5.7L V8 Specific Topics 9 03-06-2015 01:52 AM
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Vibration or wobble in 4x4 high dankent 2011 Dodge Ram Forum 5 10-29-2011 05:44 PM
Death wobble = axle swap fundaddy75 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 11-08-2010 10:50 PM
high angle ball joints? tinniste 079 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 07-10-2010 01:19 AM
