Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 10-29-2011, 09:23 PM
Ironsides Ironsides is offline
Vehicle: 2009 Dodge Ram 1500 CC 4X4
Trim Level: SLT Big Horn
Rep:44
Ironsides is on a distinguished road
Default 2009 Ram 1500 Integrated Trailer Brake Controller Install
Guys,
I put together a procedure based on my recent ITBC install in my '09 Ram. It's based on information I found on a bunch of different forums, and it's the closest thing to a factory install that I could do. All I'm missing is the software, which I don't think will ever be made available.
Enjoy.
Old 10-29-2011, 10:30 PM
MADDOG MADDOG is offline
Rep:22
Nice work! I like the write up a lot. Gonna move this over to our Knowledge Base.
It sucks they don't have an update for the 09's.
Old 10-30-2011, 10:21 PM
ken99 ken99 is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Austin Tan Pearl
Rep:26
ken99 is on a distinguished road
Outstanding. This post has application on any 4th generation truck not wired for the ITBM. Finding a source for the Yakusaki connectors is worth the post alone. Reps to you.
Ken
Old 10-31-2011, 11:57 AM
Rep:44
Ken
Thanks. The information posted by you and netman66 was the basis for most of what I did.
Old 04-11-2012, 12:09 AM
Mengstro Mengstro is offline
Vehicle: 2009 ram 1500
Mengstro is on a distinguished road
Good write up! I just hooked up the factory controller in my 2009 Ram Sport. In the attachment are a few things that I found useful for my install, like pin layout, etc. Hope this helps.
Old 07-11-2012, 08:28 PM
DavidH DavidH is offline
Vehicle: 2009 Ram 1500 Quad Cab
Color: Metallic Beige
DavidH is on a distinguished road
I called SMD and the minimum quantity they will sell is 10 at $2.50 each. the minimum for 10 of each is $100 to get one complete harness with lots of spare parts left over. If I'm buying 10 of the connectors and enough of the terminals to make 10 sets, the cost is $225. Did you have a contact at SMD or one of their distributors where fewer pieces can be ordered?
Old 07-22-2012, 07:02 PM
NolaRam's Avatar
NolaRam NolaRam is offline
Vehicle: 2009 Ram 1500 Crew Cab TRX
Trim Level: TRX
Color: Detonator Yellow
Rep:29
NolaRam is on a distinguished road
Anyone check the partnumber for the big blue male wiring harness for 4 wires male the A harness? Part number is 56020142AB, all you need is the small A end that connects to the controller unit. May cut down on labor a little bit....
Tag on the harness from Mopar reads as follows: "This harness is for ease of installation for an electric trailer brake contrroller. The mating blue connector is located under theinstrument panel, left of the steering column. Attached to the tope of the large connector braket. [W/H P/N: 56020142AB]"
Will post photo when I can, but it is most of the A harness already made for you.
File Type: jpg mopar trailer tow kit instructions.jpg (121.9 KB, 46 views)
Old 08-18-2014, 01:42 PM
gotmopar73 gotmopar73 is offline
Color: Burnt Orange
gotmopar73 is on a distinguished road
Hi guys, new to the forum and having some issues with the install of the factory brake controller into my 2009 half ton.
I ordered the following parts online:
68146918AA - module
56045795AB - wiring harness
1EB13XDVAA - Bezel
I followed the installation manual above (great job to the creators of this).I used the Mopar wiring harness and spliced in the 4-prong yazaki connector on the other end - seems straight forward.I also used a yazaki connector for the 3-prong plug and followed the instructions to hard splice in the other end of the connector to the trucks wiring harness.Everything went well and seems good.
Fire the truck up after install, factory controller lights up and seems to get power fine, but I am getting an error message "Sb" and the trailer disconnected light flashes, that's all that it will do.Doing some digging on the internet I find that this code means "short to battery on the brake output".I interpret that this means somehow power is getting to the brakes prior to pushing the brake in the truck.After this error I double checked all of the wiring I did, ensured everything was in the right position which it was.I took out the 4-prong pigtail and tested each connection for continuity and isolation from the other wires, all checks out good.I tested the trailer brake output at the 7-pin plug at the back of the truck to see if it was somehow grounding out, but it has open loop when tested to the ground of the truck. Also with the truck on, whether the brake controller is installed or removed there is 0 volts at the trailer brake output at the back of the truck.This led me to believe that maybe I had a defective module, but swapping it out with one of our 1-ton work trucks the module worked fine in the 1-ton, and the 1-ton module flashed the same code when connected in my truck...so the issue is with my truck.
I followed the instruction manual exactly except I did not have any 22awg and 20 awg wires for the 3-prong plug so I used 16awg that I had readily available and in the right colors.I asked some guys (electrical engineers that I work with) if this would effect the can-bus system and they said no It should be fine with 16awg for this short length.Could this potentially be the issue?
I am going to take apart the 7-pin plug at the back tonight and see if I can find any issues with it, but other than that I don't know what to try.
Any help is greatly appreciated.
Thanks
Old 08-18-2014, 03:28 PM
Color: Burnt Orange
Hi guys,
Problem solved.
The .pdf instruction manual in this thread states to connect the 4-prong connectors together position 1 to position 1, position 2 to position 2, 3 to 3 & 4 to 4. However the yazaki connector is labeled:
1 2
3 4
Whereas the dodge wiring diagram is
1 2
4 3
therefore I had the 12V and blue trailer wire backwards in the yazaki connector. I found this out by disconnecting the blue wire from the connector and powering the unit up, still was giving the Sb error code, then I thought to switch the 12v and brake power wires and no she works like a charm!
Hope this can help someone else who may have the same mistake.
Integrated Brake Controller DavidH 2009 Dodge Ram Forum 26 12-31-2011 04:39 PM
dealer installed trailer brake controller DenGent 2011 Dodge Ram Forum 37 08-17-2011 08:26 PM
Trailer Brake Controller nstober Electrical 8 05-17-2011 09:43 AM
OEM brake controller flash Jgroes 5.7L (345 cu in) HEMI V8 Specific Topics 1 10-14-2010 11:48 AM
Tekonsha P3 Trailer Brake Controller Doesn't Recognize Trailer GTRDude Towing 13 05-21-2010 06:56 PM
