Old 10-30-2011, 02:25 PM
gator1922 gator1922 is offline
Vehicle: 2003 dodge ram
gator1922 is on a distinguished road
Default lowered pinion angle
I lowered with mcgaughys flip kit and spindles, now i have a shake above 55 mph. think it could be from the pinion angle. has anyone had this problem
Old 10-30-2011, 02:27 PM
It could be the angles at each u-joint.
Old 11-10-2011, 07:31 AM
joeAEKDB's Avatar
joeAEKDB joeAEKDB is offline
Trim Level: Demon
Color: Mango Tango Pearlcoat
Rep:520
I had this problem when I lowered my Silverado. I measured the pinion angle, which was at 4 degrees and then found that stock was 1-2 degrees. Bought some 2 degree leaf spring wedges, and it fixed the problem.
Cannot remove pinion from housing! wilkinson 5.9L V8 Specific Topics 1 06-11-2011 05:03 AM
pinion bearings to change spockmckoy 5.9L V8 Specific Topics 1 05-11-2011 11:45 PM
03 Ram Pinion Bearing 03Thunderroad Newbie Checkin! 9 02-28-2011 08:38 AM
having pinion gear problems rhinox420 Newbie Checkin! 13 01-17-2011 09:17 AM
Good Price for Complete Used Rear-end? marlin336 Suspension 7 03-09-2010 09:58 PM
