MOPAR DECALS
Old 10-30-2011, 02:46 PM
hurley1999's Avatar
hurley1999 hurley1999 is offline
Vehicle: 2005 Dodge Ram
Trim Level: Quad cab SLT
Rep:13
hurley1999 is on a distinguished road
Default 05 leveling question
What size leveling kit is everyone using to get as close to level as possible? Im measuring 3.5" difference front to back. I have gone back and forth between lowering the back with shackles or leveling the front with the spacer.Im leaning more toward doing the front. Any advice on what worked for those that have done it? Thanks
[CENTER][SIGPIC][/SIGPIC][/CENTER][FONT="Georgia"][SIZE="2"][COLOR="Magenta"][CENTER]PA 3" Body Lift * Daystar 2" Leveling Kit * Skyjacker 7000 Shocks * GoRhino Black Step Bars * Black Housing Headlights * 8k Hids * V-Leds * Debadged * 5% Tint & 30% Full Windsheild * AVS Taillight Covers * Recon 3rd Brakelight * LaBra Tonneau * Magnaflow To Dumps * AFe Intake * 17x9 XD Addicts * 35x12.5 Federal Couragia MT * Shorty Antenna * Pioneer headunit * Xm receiver [/CENTER][/COLOR][/SIZE][/FONT]
Old 10-30-2011, 02:48 PM
Most 3rd Gen trucks appear to level out with a 2" kit.
How are you measuring to come up with the 3.5" difference?
Old 10-30-2011, 05:14 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Depends on whether your truck is 2wd or 4x4, especially with your truck because it makes a difference whether you can use a coil spacer or if you have torsion bars.
With that much difference my guess is it's 2wd. If it is Rough Country sells a 3" lift kit for it. You can use the rear block or leave it out if you really want it level
Old 10-30-2011, 09:00 PM
hurley1999's Avatar
Rep:13
ya its 2wd and no torsion bars. Im hearing rough country makes good kits for our trucks. Ill check out the 3" kit and see what i come up with. I was it as level as possible
Old 11-03-2011, 09:07 PM
eunospeed eunospeed is offline
Vehicle: 2004 Ram 1500
Color: Champagne
eunospeed is on a distinguished road
Guys, I pick my 04 ST up on Monday and the frist thing I'm going to do is lower the rear to level-out the ride. Sounds like 2" drop shackles in the rear are on track. Rough Country is the way to go? I'll check them out, any other providers?
Old 11-04-2011, 12:52 AM
Color: Mineral Gray
Rep:177
Rough country only sells lift, you might want to drop by the lowered section and those guys could give you advise on where to get a set of drop shackles from
Old 11-04-2011, 09:59 AM
Color: Champagne
http://www.roughcountry.com/lowering...02-08_ram.html
Old 11-04-2011, 01:40 PM
Color: Mineral Gray
Rep:177
Originally Posted by eunospeed View Post
well i was wrong lol I've never seen that before
Mcguaghys also sells a 2" drop shackle if thats what you really want, its like $20 more then RC i think
Old 11-04-2011, 04:06 PM
Color: Champagne
Thanks Stang, I don't want to do it twice so I might go with the 2" and be done with it.
Old 11-04-2011, 09:43 PM
hurley1999's Avatar
Rep:13
are you 2wd or 4wd? a 2" drop in the rear on a 2wd will not level it out. A 4" will get it much closer but you will loose the ability to haul heavy weight.
Leveling kit difference? quadx350 2009 Dodge Ram Forum 15 10-21-2011 10:01 PM
Newbie leveling question joeson Suspension 5 04-19-2011 02:38 AM
Tire size and leveling question dillon00 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 04:05 PM
Question on leveling my truck Blue Bear Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 03-12-2011 03:56 AM
Leveling kit question? Quiet Lunatic Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 11-22-2009 08:32 AM
