1500 4x4 strut install - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Suspension
Old 10-21-2011, 11:49 PM
hwy97's Avatar
hwy97 hwy97 is offline
Vehicle: 2016 4 door short bed 4x4
Trim Level: Laramie Longhorn
Color: Pearl White
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
hwy97 is on a distinguished road
Default 1500 4x4 strut install
I apologize if this has been done to death, but I've searched and searched and can't find any how to. I've had the springs out of my prior Rams '04 and '06 diesels, but I'm in the dark about the struts in my current '07 1500 4x4. I've read where you have to disconnect the lower ball joint, another the upper ball joint.....is there somewhere in this forum or a link on the net that I can't find instructions. I've got front and back KYB's and a rented spring compressor and would like to get this done asap. THANKS
Old 10-22-2011, 10:05 PM
hwy97's Avatar
Color: Pearl White
One way to learn is to do....upper ball joint was the way I went to get them out.
Old 10-22-2011, 11:28 PM
ahhh...sorry I missed this yesterday..was outta town down in Roseburg and points East.
I have a factory service manual here with pictures and everything!
Old 10-23-2011, 12:49 PM
hwy97's Avatar
Color: Pearl White
Thanks anyway Maddog! Got rid of the "strange" suspension noise and a real noticeable ride improvement. Just curious, is separating the upper control arm how the manual shows? Sure is a quick way after you've done one side and figured out what how to proceed
Old 10-25-2011, 06:27 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
As someone who has had to remove the factory struts/coils, add new ones & than replace the new ones with another set of new ones all within 2 months..I can say the factory lower strut bolt will be the hardest thing if its seized. We only removed the upper ball joint & upper sway bar linkage connection on the 3rd set.
It's a truck, not a cream puff
Old 11-12-2011, 12:34 AM
Husker13 Husker13 is offline
Vehicle: 2007 Dodge Ram 1500
Husker13 is on a distinguished road
I just got done replacing mine and I couldn't get the upper ball joint to come off the passenger side. I didn't want to damage it, so I am here to say that it is possible to get the strut out with only disconnecting the sway bar.
I would not recommend this method, but in a pitch you can do it with a 2nd person.
problems removing the lower strut bolt on 2006 1500 breck83 Suspension 9 04-18-2014 05:19 PM
write up on the new 2012 ram 1500 sirrednexx 2012 Dodge Ram Forum 4 05-20-2011 01:45 PM
2010 Ram 1500 rims on my 2002 Ram 1500? shaded02 LD RAM - General Discussion 3 05-05-2011 09:21 AM
Will Dodge Ram 1500 2010 Wheels and Tires fit a 1998 Dodge Ram 1500? koalatyman Dodge Ram Wheels And Tires 1 04-14-2011 10:38 PM
Differance Between the Ram 1500 R/T 5.7L vs Ram 1500 5.7L 345 RT Dodge Ram R/T 23 07-28-2010 08:02 PM
