Front Wheel Bearing/Hub Assembly - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-31-2011, 06:45 AM
fxdrider fxdrider is offline
Vehicle: none
fxdrider is on a distinguished road
Default Front Wheel Bearing/Hub Assembly
I've got the dreaded wheel bearing noise coming from the left front wheel. It's starting to sound like I'm riding in the cabin of a propellor-driven airplane. I'd like to do the work myself and save the huge chunk money the dealership will undoubtedly want for it, and I found this How-To video on YouTube:
Question is - is it really as easy as it looks in this video? It seems like the worse part was loosening the 3 bolts that hold the hub on.
Old 10-31-2011, 10:06 AM
RedneckMechanic RedneckMechanic is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Rep:28
RedneckMechanic is on a distinguished road
Yes, it really IS that easy. BUT, those bolts are torqued to 100+ ft-lb... Gonna take a serious breaker bar to get them loose. Also, getting the hub assembly to separate from the knuckle can be a pain. Usually a few good hammer hits to the perimeter of the hub assembly will break the rust and dirt loose. (Hit it to try and turn the rotor in the spindle, misaligning the holes) Then with either a pry bar, or a hammer work all the way around to pop it loose. I usually rap the back side of the hub flange (don't hit the backing plate for the brakes) pretty hard and it's usually enough to get it out. Going to take some work. It's not just gonna fall out.
When it comes time to reassemble, make sure the spindle hole is cleaned free of any residual dust and dirt, insert new assembly into hole, then use the bolts to suck it in. Go a few threads at a time until it's fully seated. I, personally, usually put a little dab of blue Loc-Tite on the threads JUST to make sure I don't have problems later. And do make sure to torque them. Lord knows you don't want that stuff falling apart doing 60+ down the highway...
Old 11-01-2011, 06:30 AM
Vehicle: none
Well, I was all set to do it - bought the Timken hub assembly at AutoZone. I decided to call the local dealer to see what the job would cost in case I got stuck at some point. They said they'd install my part for $178. I thought about it for a moment, and told them "I'll be there in an hour".
I know...I'm a chicken.
Old 11-02-2011, 01:37 PM
Rep:28
No shame in admitting when you think you might be in over your head. Nothing sucks more than trying to do a job on your daily driver and realizing A) you don't know how to complete the job and B) you don't have the tools to do it right. $178 isn't too bad. Glad you were able to get it done though.
Old 11-03-2011, 10:37 AM
Vehicle: none
That's exactly what I thought. I could just imagine busting off one of the hub mounting bolts or something - then I WOULD be in a bind.
Old 11-18-2011, 01:48 PM
dfskinner dfskinner is offline
Vehicle: 2004 Dodge Ram 1500 SLT 4X4
Trim Level: Quad Cab 5.7L Hemi
Color: Burgandy
dfskinner is on a distinguished road
fxdrider where in Va are you located?
I just tried to replace my hub assembly on the passanger side... spent about 2 hours at the base hobby shop and couldn't get the drive shaft to slide off the transaxle.... not enough room to slide it towards the axle.... I also watched the video posted above, but they left off a step where they apparently dropped the axle to make room to remove the drive shaft for a 4X4 vehilce..... I've still got my assembly, just not sure how to perform the last step... I'm looking for some step by step instructions (I'm working on the passanger side)..... if anyone has any tips....
clicking in left front wheel well area SPARTACUS 2010 Dodge Ram Forum 12 05-01-2011 06:41 PM
front wheel bearings ggjjcarl Newbie Checkin! 11 09-01-2010 12:28 PM
Front Wheel Bearing 2005 Ram 1500 DJTR 5.7L V8 Specific Topics 11 04-29-2010 03:23 PM
right front wheel bearing went out TASSY5 Suspension 4 04-26-2010 11:05 PM
Wheel hub assembly ? 972500V8 5.9L V8 Specific Topics 0 02-28-2009 12:44 PM
