Gear change ? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-31-2011, 02:41 PM
Devildriver82 Devildriver82 is offline
Devildriver82 is on a distinguished road
Default Gear change ?
Hey fellas. Im new on here and looking for advice. I have a 2010 ram 2wd hemi reg cab, 20" wheels with 3.21 gears. Im wanting to upgrade. Just wondering if you would go to 3.92 or 4.10 with limited slip. Either way i know its going to be a big jump for me. Maybe what brand you would go with.
Also, i have been told no need for speedo change. Anything else i will have to worry about. I do have a superchip flashpaq as well. Thanks
Old 10-31-2011, 03:00 PM
Rep:2968
There are a few different sources to check out
look in our Vendors section, you may get the best discount through them
then of coarse you could get it through your dealership
you may want to check out these sites to get more information about the 9.25 rear end
http://www.ringpinion.com/
http://www.motivegear.com/pages/ring...nion_gears.htm
http://www.richmondgear.com/
http://www.drivetrain.com/parts_cata..._pinioins.html
Welcome to the RamforumZ
Old 10-31-2011, 03:33 PM
3.92 seems to be the most popular.
Old 10-31-2011, 04:52 PM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2016 RAM 3500
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
Rep:48
rsg1963 is on a distinguished road
If I was switching from that ratio, I'd get the 4.10's instead of the 3.92's because I tow often and every little bit helps in that area. These trucks lack in the low-end area IMHO anyway, so it could only help in the city too. Besides, not much difference between the 3.92-4.10's anyway so why not go a bit higher? (numerically)
2016 3500 MC 385/900 with Aisin tranny & 4.10 gears: Fox 2.0's, Amsoil Oil Bypass, 20" Fuel rims with 275/65-20 tires, Juice w/attitude controller, Weathertec Floor mats, 45 gal RDS tank, Hensley TS3 hitch, Amp Research steps, hybrid window tint.
Old 10-31-2011, 08:08 PM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
3.21's should never have been in these trucks to begin with.
With 17's 3.55 is minimum. With 20's the 3.92 is minimum.
Since you already have a Superchips so you can adjust for different ratios and 20's I would go 4.10. That will be similar to the 3.92 17" combo in rpm.
Gene
Old 11-01-2011, 06:21 PM
SteveO's Avatar
SteveO SteveO is offline
Vehicle: 2013 Dodge Ram
Trim Level: Sport 4x4
SteveO is on a distinguished road
This is the best package I have found..
http://moesperformance.com/index.php...r_of_uploads=0
Old 11-02-2011, 02:32 PM
I think i will get the mopar gear set with detroit true trac 3.92 package. One shop told me i will hear alot of noise with motive or richmond gears. Maybe they just dont know what they are doing too. They said they will only use mopar gears in dodges for that reason
Old 11-02-2011, 02:38 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
5% parts 95% install imo
Old 11-02-2011, 02:43 PM
moparornocar72's Avatar
Rep:630
exactly! perfect advice!
14.268 @ 95 MPH Full Trim
Old 11-02-2011, 03:25 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I third what kay9 said. I'd get 4.10 over 3.92 if you are going through the expense and trouble of the swap.
Sean
Cost to change rear gear ratio. TJB10 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 22 06-25-2013 11:19 PM
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 12:23 AM
45RFE sensors and rear gear change partymn Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 11-28-2010 08:45 AM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
2010 Hemi Sport Gear Change...? chad3113 2010 Dodge Ram Forum 24 06-24-2010 12:16 AM
