Help with rear shackle replacement PLEASE! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 10-31-2011, 04:41 PM
hamster01340 hamster01340 is offline
Vehicle: 1998 dodge ram 1500
hamster01340 is on a distinguished road
Exclamation Help with rear shackle replacement PLEASE!
1998 ram pickup Both rear shackles are rusted out. just the old bolts are left and the leafsprings are touching the bed of the truck. Could someone please tell me the easiest way to replace these. I have the parts but three different people have told me three different ways.
Old 01-10-2012, 01:57 PM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
easiest way would be to jack up the truck and set it on stands (under the frame, not the rear axle), pull the old bolts out, and bolt the hangers to the frame, and jack up the rear axle to line up the eyelets with the shackles to slide the bolt through
Old 01-10-2012, 07:14 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
^That's what I'd suggest.^ Jack up the back of the truck and put some jack stands under the frame just before the rear axle. If you have access to a torch burn the rivets from the outside of the frame and what's left of the old hangers will protect the frame to a certain extent if you're not very skilled.
Either that or you'll have to grind them off. Once you get the heads off the rivets you can knock the old one out.
Since the frame is supported by jack-stands it's easiest to put the jack under the rear axle and take the tire off (doing one side at a time). Use at least grade 8 bolts and nuts to put the hangers back on and then hang the springs on the shackles. I had my bed off which made it a whole lot easier.
Old 02-07-2012, 12:50 PM
desolit desolit is offline
Vehicle: 1995 dodge ram 1500
Trim Level: sxt
Color: green/silver
desolit is on a distinguished road
I know im late. But for anyone else that experiences this problem i had a hell of a time doing this.
when mine rusted out i didnt want to unbolt the fronts in fear of snapping the bolts because my truck is an old rusty-but-trusty.
no matter waht i didn to jack up the truck i couldnt get the spring low enough to line up the shackle bolt. what i ended up having to do (which i dont recommend because it could be dangerous but in a pinch it works) is lock a chain around the back end of the spring and hook the other end to the base of the jack. then jacked it up slowly. This held the spring in place while the truck rose above it.
hope it helps.
shackles
Rear Shock Replacement?? chadob69 2009 Dodge Ram Forum 13 02-06-2016 10:45 AM
Rear bumper replacement, should or can I add backup sensors? Racerdamon Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 2 08-17-2011 12:43 AM
Rear End Replacement Costs jjklongisland LD RAM - General Discussion 4 02-19-2011 12:33 PM
Help!!! Rear Bumper replacement distributors? jwt355 2011 Dodge Ram Forum 7 02-14-2011 11:56 PM
97 Ram 1500 4X4 Rear Shackle Replacement deringer Suspension 4 08-14-2009 02:17 PM
