Old 10-31-2011, 08:13 PM
Danstona Danstona is offline
Vehicle: 2005 Dodge Ram 1500 4x4 5.7L
Trim Level: Hemi Sport
Rep:35
Danstona is on a distinguished road
Default 05 Ram foglight issue
I have installed HID's in my foglights and they were working great for over year. The last while I had issue's with the lights coming on and then going out about 10 seconds after turning them on.. I just assumed that was a bad ballast and I have installed new ones which seemed to help for a bit.. My issue now is that only my passenger side fog works... I was having problems with the drivers side before, where it was going out.. I changed the bulb then the ballast and now its completely dead? I tried swapping back in a bulbs and ballast that had been working intermittent and still nothing. Does anyone know what causes the ballasts/bulbs to go bad on these things? Also the main question is, is there a separate fuse for each fog light? I only see a single fuse and relay.. fuse location #41 in the fusebox under the hood. Thanks for any insight. Dan
Old 10-31-2011, 09:25 PM
One fuse for the circuit, Dan, so if you lose one but not both fogs, it's not a fuse issue.
I can't imagine you have a bad bulb and ballast unless the previous ballast that was going bad blew the bulb.
Did both fogs flicker when you were initially having problems?
Old 10-31-2011, 09:36 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Like MADDOG said, there is only 1 fuse for both, and they share the same relay.
The power from the relay feeds a splice that distributes to both lights on the White/Yellow wire, so you can test it for power. If not there, follow it back to the splice and repair as necessary. The ground (Black wire) also feeds back to a splice to join up with the ground from the other side.
If you test between the black and White/Yellow wires and have power, then the problem lies in the ballast or bulb or both.
brad
Interested in one of my mods?
Old 11-01-2011, 08:41 AM
Rep:35
Thanks for the replies guys. And thanks for moving my post, its so confusing over here now, knowing where to post and all and to get a healthy number of views for a response. Anyway, I was hoping to get home from work tonight to check for power and if I do have power, then I was going to put in an entire new kit. I didn't think there was a separate fuse or relay, but I wanted to be sure. With the issues I've had on that light I wouldn't be surprised there is a ground issue on that side. Just given the chracteristics of my issue. Maddog - I've had trouble with both fogs, but mostly drivers side. Never a flicker, just drops out, usually solvable by turning off and back on, assumed it was weather related. Ill post back what I find. Thanks.
Old 11-16-2011, 05:26 PM
Rep:35
Managed to find the culprit.. all is working well now for several days. Turned out that I had 1 bad bulb and also a bad connection on the plug... very worn and corroded terminals. Now if only I could find some help with my girlfriends 04 Mistu Lancer! What a pita that thing has been with its Bi-Xenon kit.
Backup Camera Issue (barcam 221) hugecanoli Dodge Ram General Discussion 1 10-12-2011 09:07 AM
C-clip/rear diff issue...info and questions starquestbd22 4.7L PowerTech V8 Specific Topics 8 08-28-2011 06:27 PM
Lazy/non-existent downshifts - anybody else with this issue? Turbovsix 2010 Dodge Ram Forum 18 05-20-2011 11:48 AM
RUST issue with 2010 4x4 Ram Big Horn...anyone else having this issue SupermanWV 2010 Dodge Ram Forum 18 01-29-2011 09:42 PM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-12-2011 11:30 PM
