Tailgate seal - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-01-2011, 01:39 AM
EVS1's Avatar
EVS1 EVS1 is offline
Vehicle: 2011 Dodge Ram Sport
Rep:12
EVS1 is on a distinguished road
Default Tailgate seal
I just installed a roll back type bed cover on my ram, but can't find a seal for around the tailgate that is thick enough. Any suggestions?
Old 11-01-2011, 11:23 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Looking for one myself - Which brands have you tried?
Old 11-01-2011, 11:54 AM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
The problem is the way that the gate meets the bed on each side, there is a huge gap there that NO tailgate seal is going to close up.
Try this, put a flashlight in the bed pointed towards the tailgate and then close it. Look at how big the gap on each side is.
Maybe is you folded up a towel and jammed it in there!
Old 11-01-2011, 05:39 PM
EVS1's Avatar
Rep:12
I tried what the shop had where I got the cover, no luck.
Old 11-01-2011, 07:05 PM
lowrpmtork's Avatar
lowrpmtork lowrpmtork is offline
Trim Level: Sport Crew Cab 4x4
lowrpmtork is on a distinguished road
What about a self-stick bulb seal? If seen several sizes at Lowes/Menards that look like they'd work without being too getto.
2011 Ram 1500 Sport Crew Cab 4x4
Yeah, it's got a Hemi...
Old 11-01-2011, 08:15 PM
53fireman 53fireman is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman RAMBOX
53fireman is on a distinguished road
I've tried this one - http://www.amazon.com/Lund-30002-Gen.../dp/B000COL4A4
it works OK on the sides and along the side of the rail. I have RAMBOXES, so my rail is a little bigger. I don't like how it fits on the bottom of the bed. The tailgate pushes it down and the sticky tape is exposed a bit, so it's probably going to fall off sometime soon. I'm not sure if I put in a bad spot, but with the way the tailgate moves when you close it, it seemed like the best spot to put it.
Old 11-01-2011, 08:57 PM
EVS1's Avatar
Rep:12
I'll stop by the dealer and see if the Rambox has any smaller gaps than the regular bed, also wondering about the bulb seal that lowrpmtork mentioned. Maybe something for a garage door.
Old 11-01-2011, 09:22 PM
doug713's Avatar
doug713 doug713 is offline
Rep:33
doug713 is on a distinguished road
I have had a bakflip cover on my truck for almost a year and have never seen much if any water get into the bed in the hardest of rainstorms and while driving through them. What are you guys worried about in the bed thats going to get wet? Just curious, because if you have a good cover that should do it.
Old 11-01-2011, 10:21 PM
EVS1's Avatar
Rep:12
I had a Leer fiberglass cover on my '99 Ram and it would suck water in around the tailgate and cover everything inside with a fine mist. I want to be able to put luggage and other travel items back there and keep them dry.
Old 11-02-2011, 01:33 PM
Barnyard's Avatar
Rep:209
They are probably getting a lot of dust in the bed (not water). If the top isn't completely sealed you create a low pressure area inside the bed and road dust is drawn in the gaps around the tailgate.
How-To: Installing Power Tailgate Lock iRockCrawler Dodge Ram Knowledge Base 68 09-24-2016 11:54 AM
Tailgate seal? Turbovsix LD RAM - General Discussion 11 11-11-2011 10:22 PM
Newbie in KY, have a tailgate question mr61impala Newbie Checkin! 5 09-28-2011 11:00 PM
Tailgate seal??? Curly 28 2011 Dodge Ram Forum 8 08-04-2011 09:22 AM
Passenger Front Axle Seal Mcgyver 4.7L PowerTech V8 Specific Topics 4 10-31-2010 10:44 PM
