Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 11-01-2011, 04:18 PM
CanuckHRAM's Avatar
CanuckHRAM CanuckHRAM is offline
Vehicle: 2011 Ram Quad Cab 4 x 4
Trim Level: SLT Outdoorsman
Color: Deep Water Blue Pearl
CanuckHRAM is on a distinguished road
Default 2011 Outdoorsman - Rear Sag When Towing
Hello,
Traded my 2003 RAM in for my new 2011 Outdoorsman. Love this new truck but when I hook up my 6000 Lb. Travel Trailer the truck sags noticeably. Same set-up used (Load Levelers) and same trailer that my
2003 towed with no sagging until it was 6 years old after which I installed a Firestone Air Bag system in rear.
I am disappointed that my new truck cannot carry this weight without sagging yet my 2003 had no problem doing so when new. Is it the coil springs system? Wondering if others have this problem and if there is anything that Dodge can do? 2011 tows great but the sag sucks.
Thanks!
Raider Phantom Topper, K&N Drop-In Air Filter, Vent Visors, SmittyBilt Light Bar & PIAA Lights
Old 11-01-2011, 04:29 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Just my opinion but I don't know why people get upset with sagging when putting thousands of pounds on the back of a truck...it's supposed to do that. The coil spring suspension is really a good setup, superior to leafs in every way. It is, however, possible that there is more travel in the coil system vs. the leaf system, as in maybe there is more overall travel to achieve the same payload...
Sean
Old 11-01-2011, 07:03 PM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
I agree with snrusnak, I wouldn't worry about it too much. If you are really looking for a solution, I would start by checking the tongue weight of the trailer. Try to balance your load so that there is just over 600 pounds on the tongue (10% of total load). Maybe your tonque weight is higher than it needs to be right now.
2013 F-150 King Ranch 4wd 5.0
Old 11-01-2011, 10:26 PM
I agree...check that tongue weight on the trailer.
Even then, I'd suggest you consider a set of air bags for the back. The Ride Rite kit from Firestone is a good one.
Old 11-02-2011, 11:36 AM
CanuckHRAM's Avatar
Thanks everyone for your honest opinions. I could play with the weight distribution in my trailer but it may not make the difference I am looking for. I do realize that the new coil spring suspension is superior in most respects, especially ride quality, but it's just a little surprising that
the rear sag is there.
I did install a Firestone Ride-Rite set of rear air bags on my 2003 and they worked great. This will probably be the route I take with my 2011 knowing the product and what it can do.
Thanks again everyone!
Old 11-02-2011, 11:51 AM
snrusnak's Avatar
Rep:1388
^ I think there is more sag just because there is more travel in the suspension (although I have no verification of this....I could measure the travel in mine and compare to someone who measures the travel of their leafs...). I would second the airbags, they are very easy to install on these trucks too, there's a nice large plate on the axle (almost as if they wanted you to install bags lol).
Sean
Old 11-02-2011, 03:08 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Thumbs up New Air Suspension System for RAM 1500
Total Load Control™ is a patented new air suspension for coil spring RAM 1500. We recently introduced it on the Z and hope you'll be our next customer!
We add 2 tons of lift power with 9" Goodyear air springs that not only level any legal load but also improve handling, steering, braking and ride - loaded and unloaded.
TLC™ tightens the rear end to virtually eliminate understeer and oversteer without interfering with the ride or factory suspension. In fact, our customers prefer the unloaded ride with TLC.
TLC bolts on and is easy-to-install.
Please check out our Z vendor page or website: TotalLoadControl.com.
We have a $100 off special running until Thanksgiving if you put in the code RAMZ at checkout.
If you have any questions, please let us know.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 11-02-2011, 03:46 PM
Rep:2804
Believe it or not, Ram trucks will be getting air springs in a while, i don't know yet if the 2012 model has them as an option
The coil springs are ok if you use your Ram 1500 as a pleasure vehicle, when you go to the home improvement store & load up, the coils need HELP
They can BS all they want, they needed more gas mileage per the Federal Regs & went to coils, lots lighter than leaf springs, the 2500 & 3500 models don't have to comply with those Regs
The 2011 rear ends are 40 pounds lighter that the 2010, another gas mileage improver
The next thing they are going to do, is to stop giving you a spare tire, instead you will get a jack, a tire plug kit & a electric mini air pump, some makes of vehicles already are doing that, another mpg saver
Old 11-04-2011, 11:52 AM
CanuckHRAM's Avatar
Thanks for the product heads-up TLC John. I will visit your website and let you know if I have any questions.
Old 11-11-2011, 09:07 PM
Zeus Zeus is offline
Vehicle: 2011 Ram 2500
Color: Rugged Brown
Rep:27
Zeus is on a distinguished road
TLC system adds more capability than the others but it is also a lot more expensive. I like it. Just not sure I want to spend the money. Has anybody ran any of the bags that go inside the spring?
2011 outdoorsman bumper Bdiver 2011 Dodge Ram Forum 7 11-14-2011 01:49 PM
2011 Steel Rear Bumper w/o duel cutouts Zippo973 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 9 08-20-2011 07:16 PM
Towing with our new 2011 2500 Hemi t05ks Towing 1 07-25-2011 10:24 AM
2011 Towing; Good, Bad, and the Ugly Quiet Lunatic Towing 9 09-17-2010 11:34 PM
