Ignition Issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 11-01-2011, 06:30 PM
cqb2004's Avatar
cqb2004 cqb2004 is offline
Vehicle: 2013 2500 SLT
cqb2004 is on a distinguished road
Default Ignition Issue
Has anyone replaced their stock ignition? I am starting to have problems with mine. Every other attempt to start the truck takes me a couple of minutes of jiggling the key and steering wheel to get the ignition cylinder to turn to start the truck. Im guessing the cylinder is done. My local Dodge dealership wants $150 for a new cylinder and $95 per hour labor. Looking to purchase and Install myself. Degree of Difficulty?
Old 11-02-2011, 01:33 PM
RedneckMechanic RedneckMechanic is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Rep:28
RedneckMechanic is on a distinguished road
The ignition lock cylinder isn't too hard to do. Here are the steps to replace it:
Of course one of the first steps is to remove the clam shell...
REMOVAL
The ignition key must be in the key cylinder for cylinder removal.
  1. Disconnect negative cable from battery.
  2. Remove upper and lower covers (shrouds) from steering column.
  3. Place shifter in PARK position.
Fig. 12
  1. A retaining pin is located at side of key cylinder assembly.
(a) Rotate key to RUN position. Fig. 13
(b) Press in on retaining pin while pulling key cylinder from ignition switch. INSTALLATION
The ignition key must be in the key cylinder for cylinder installation.
  1. Install the key cylinder into the housing using care to align the end of the key cylinder with the ignition switch.
  2. Push the key cylinder in until it clicks.
  3. Replace the upper and lower shrouds.
  4. Reconnect the battery.
Backup Camera Issue (barcam 221) hugecanoli LD RAM - General Discussion 1 10-12-2011 09:07 AM
C-clip/rear diff issue...info and questions starquestbd22 4.7L PowerTech V8 Specific Topics 8 08-28-2011 06:27 PM
Lazy/non-existent downshifts - anybody else with this issue? Turbovsix 2010 Dodge Ram Forum 18 05-20-2011 11:48 AM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
Ignition problem andrewdains Electrical 2 05-22-2010 02:35 PM
