Old 06-28-2012, 08:24 PM
Rep:2616
I had the same problem, i was in a down pour, hands full of paper grocery bags & the Fobs didn't work, Ram was still under Warranty
They gave me 2 new Fobs & kept the old ones.
Not much of an issue now, just once in a while i have to click the FOB more than once,
When it doesn't work after a few presses, i start the Ram remotely & then click the unlock button
I asked around & it seems that sometimes the communication between the FOB & the Ram can be on a different transmitting cycle
It also happens with my Homelink garage door button on occasion, ust when trying to get it to open, never when closing
Old 07-01-2012, 07:21 PM
readster1's Avatar
Vehicle: 2011 dodge ram
Trim Level: Long horn/sport
Color: brilliant black pearl
Rep:12
how do you open the fob to change batts,don't need to just curious
Old 07-02-2012, 12:53 PM
dkerr24 dkerr24 is offline
Vehicle: 2011 Dodge Ram
Color: Dk Cherry Red
Rep:14
dkerr24 is on a distinguished road
Changing the battery in the fob is pretty easy... just remove the built in key from the fob, then gently pry the fob apart from the inside where you removed the key. The fob uses one CR2032 coin cell battery.
Darin
Old 07-02-2012, 08:30 PM
Hogking Hogking is offline
Vehicle: 2011 Dodge Ram 1500
Rep:103
Hogking will become famous soon enoughHogking will become famous soon enough
I rotate my keys every month. Was told this was the best way to keep fob current. Someone said that each fob has a limited number of clicks before it shuts itself down. By rotating it every month it resets itself back to zero!
Old 07-02-2012, 10:14 PM
RansRAM's Avatar
RansRAM RansRAM is online now
Addicted to the Z
Color: PX8 Black
Rep:2471
Mine started acting up so I took it apart and cleaned the contacts. It worked for awhile however has started acting up again. I've noticed that I can continue to press the open and nothing happens. What I have discovered is that if I press the lock first to relock it I can press the open and it works on the first press. Weird but it works. So I don't think the issue is related to a dead battery, more likely the software.
Old 07-02-2012, 10:29 PM
DILTS's Avatar
DILTS DILTS is offline
Vehicle: 2006 Dodge Ram
Color: BLACK
DILTS is on a distinguished road
so anyone know how to disable the alarm from going off when you use the key to open the door?
6" bds, bilstein 5100, CAI, TB spacer, superchips vivid, trifold tonneau, 35's.
Old 07-03-2012, 05:51 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Thanks for the info. I too will stock up on some.....
Old 07-15-2012, 02:01 PM
NorthernGuy77 NorthernGuy77 is offline
Vehicle: 2011 Dodge Ram 1500 Lone Star
Trim Level: Lone Star
NorthernGuy77 is on a distinguished road
Thanks for the info! I will have to take it in and see about getting it replaced. Only having one is driving me nuts! I need an oil change anyways so it is a great reason to go in on top of that!
Dead FOB? bmwbutch 2011 Dodge Ram Forum 5 06-15-2011 08:54 PM
Alarm & Dead Battery jfmaire Electrical 1 03-30-2011 12:53 AM
2006 ram condenser motor dead 06hemilongbed Newbie Checkin! 11 03-17-2011 12:30 AM
Your Duck is Dead RootBeer Jokes/Humor 9 12-16-2010 05:58 PM
Washed engine now truck is dead castorriver Electrical 8 04-30-2010 12:40 AM
