back fire - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 11-02-2011, 12:03 AM
o1dodge.ram1500's Avatar
o1dodge.ram1500 o1dodge.ram1500 is offline
Vehicle: 2001 dodge ram
o1dodge.ram1500 is on a distinguished road
Default back fire
long story short....truck was perfect one day then took it to my dads friends shop to get a couple things replaced, then the next day i got it back it started to back fire.... have asked several people on what to do and no one seems to know....
Old 11-02-2011, 02:13 AM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
what was done to it at the shop?
Old 11-02-2011, 09:06 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Yeah more info, what was done?
Sean
Old 11-02-2011, 03:16 PM
had the spark plugs, wires, cap and rotor replaced by my dads friend who owns a shop, got my truck back and started the back firin when im tryin to keep at a constant speed. took my truck to my friends dads shop he said that they have the wrong plugs in it (platnum champians). so i went and bought original spark plugs(copper risisters) and replaced them all. it started to go away when i test drove it that night, but next day went back to back firin.
Old 11-02-2011, 03:29 PM
snrusnak's Avatar
Rep:1388
Sounds almost certainly like it is a distributor/wires/plugs problem, so that makes sense. There's a bunch of things that could be wrong:
Wrong plugs
Wrong gap
Loose connection of plug to wire or wire to distributor cap
Cracked distributor cap
Rotor installed backwards(not sure if this is possible, been so long since I've touched one)
Wires got mixed up and firing order is off
Bad wires.
I'd start by checking the firing order and where the wires go and make sure they are located correctly, and that all connections are good. Then check plug gap. Also check for obvious things like rotor installed correctly, cap not cracked and is tight, etc...
EDIT: Also, does it only do it at low rpm? Could be a slightly loose plug, make sure they are all snug.
Sean
Old 11-02-2011, 03:32 PM
snrusnak's Avatar
Rep:1388
Also, use the oem plug, not some other plug, my experience is that things almost always run better with oem plugs...
Sean
Old 11-02-2011, 06:21 PM
well i know i have the right plugs and that the gap is right, and im pretty sure i snugged them good doesnt hurt to double check. maybe the guy put mixed up the wires....how do you figure out which wire goes where?
Old 11-02-2011, 06:29 PM
also....when the guy replaced all that and after i figured out that my truck was back firin i turned around and took and back to him and he double checked everythin and said that the reason that it could be back firin is because when he replaced the spark plugs the old ones were corrodedand when he put new ones in the truck got better connection and that the back fire has probably been there the whole time and i probably didnt notice it....i dont believe it was ever back firin it ran pretty good before i took it to him ..... also when my truck does back fire it also shakes a little be. and it starts to do it when im goin bout 40 or higher...but doesnt start doin it till the truck warms up
Old 11-02-2011, 07:56 PM
snrusnak's Avatar
Rep:1388
Yeah he's full of it....I'll try to find a diagram for your engine so you can double check the wires....
Are you using an oem type plug?
Sean
Old 11-02-2011, 08:08 PM
snrusnak's Avatar
Rep:1388
Here, you can check the wires are correct with this:
If that's good, then I'd do this:
Check the firing order. Unplug the coil, remove the number one plug, stick your finger in the hole, have someone click the engine over in short bursts until the number one piston is at the top (it will blow your finger out of the hole as its coming up). Line up the timing mark on zero at the front pulley and remove the distributor cap and see if the rotor is pointing at the number one plug. Verify firing order is 1-8-4-3-6-5-7-2
Sean
back pressure? creed0423 Exhaust 17 04-15-2011 02:41 AM
just got a flowmaster cat back system have a ? for u all ram8308 2009 Dodge Ram Forum 5 03-19-2011 02:03 AM
Just got ren and back up cam installed have a question Ray 2010 Dodge Ram Forum 7 03-10-2011 09:45 PM
Bought a new truck a few months back and nothing but problems at first! heffs03mach1 2010 Dodge Ram Forum 8 02-03-2011 10:33 PM
Back In A Ram, New To The Forum 2010NebBigHorn Newbie Checkin! 10 01-04-2011 06:26 PM
