Adding more lift - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-02-2011, 08:03 PM
2000RAM's Avatar
2000RAM 2000RAM is offline
Vehicle: 2000 Dodge Ram 1500
Trim Level: sport
Color: yellow
2000RAM is on a distinguished road
Default Adding more lift
Hey everyone, So i have a fabtech 5.5 inch lift with 35 inch tires on my 2000 ram reg cab short bed. I want to see if anyone has any imput on this. I want to add 3" coil spacers to the front. Now if I add those spacers will my front tire not be cernter in the wheel well anymore? and stuffed into the fender? and also with the driveshaft angles, is the angle going to be too great? Also adding 3 inches will give me 8.5 inches of sus lift. I want to maybe add a 2 inch body lift and 38-40 inch tires. Ik theres a lof of questions here haha. OH! and what about the steering??? will i get death wobble due to adding 3 more inches of sus lift? And can someone tell me what they would do to lift the rear? it has 3-3.5 inch blocks and a add-a-leaf. and i wana be level with the front.
Hope someone can help!!!! Thanks Guys!!!!
Old 11-02-2011, 08:46 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
You can do that but it's highly recommended by almost all lift manufactures to not use spacers ontop of a lift.
Unless you have an adjustable trac bar or find another drop mount for the height your looking for the you axle will be off center. Not only will it pull it into the passenger fender and push it out of the drivers side, it also pulls the axle back towards the cab of the truck(think of how control arms work). You will probably need a new pitman arm too.
If you don't happen to get death wobble you'll probably blow u joints, especially trying to spin that big of a tire with stock axles.
Going that big is really expensive, trying to cut corners is just going to cost you alot more in the long run.
Just my $0.02
Trying to get the most height mustang26 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 10-16-2011 06:38 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
Adding to my lift bransonshemi Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 11-08-2010 09:23 PM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 12:28 PM
