Old 11-02-2011, 09:02 PM
jj1913's Avatar
jj1913 jj1913 is offline
Vehicle: 1999 dodge ram
Color: Red/Maroon
jj1913 is on a distinguished road
Default Cab switch?
I have 99 Ram regular cab with a long bed.
Bed is a work bed and dont really use it for
work. I was wondering if i could replace the
cad with a extend cab and throw on a short
bed. Ideas on this...I love my dodge, its just
id like to be able to make her look good.
Old 11-02-2011, 09:05 PM
It'll work. The main wiring harness should be the same. Body mounts and bed mounts will have to be changed out and moved.
Old 11-03-2011, 01:41 AM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
yup, the rear cab mounts and front bed mounts will have to be moved back to acomidate the longer cab and short box. should be able to use the wire harness from the extended cab, just plug n play
Old 11-03-2011, 01:54 AM
Rep:2657
Most every frame has all the proper holes for every cab mounting
they make them all the same, except for the different changes for long or short frame
like an extended cab short bed, will use a different frame from a extended cab long bed
maybe as much as 12" to 20" difference for instance
cabbin switch
Bedrug, bedlights, and cargo switch done. gingrbredman Custom Dodge Ram Interior and Exterior Lighting 16 11-28-2011 03:02 PM
Need help wiring new switch for new fog lamps! RamSki Custom Dodge Ram Interior and Exterior Lighting 3 07-16-2011 12:35 PM
check guages light on DODGEARCHER Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 06-22-2011 10:21 PM
Drivers door lock switch......... bigdaddyII Electrical 9 01-25-2011 11:09 AM
horn separate switch dead short..help! String13 Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 12-31-2010 09:20 AM
