Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 11-02-2011, 11:23 PM
turbomir turbomir is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: 1500
turbomir is on a distinguished road
Default Heater core
Have a question my heater core is bad . Is there a easy way to get to it. O i have to take dash apart ? thanks
Old 11-02-2011, 11:59 PM
Dalton's Avatar
Dalton Dalton is offline
Vehicle: 2005 Dodge Ram Daytona
Trim Level: Daytona
Rep:43
Dalton is on a distinguished road
You have to take the dash apart. I think it took me six or eight hours but i cheated a little. I made a thread telling how to do it without draining the a/c system. Its been a year now and everything is still working good.
Old 11-03-2011, 08:20 AM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
REMOVAL
WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS, DISABLE THE AIRBAG SYSTEM BEFORE ATTEMPTING ANY STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENT DIAGNOSIS OR SERVICE. DISCONNECT AND ISOLATE THE BATTERY NEGATIVE (GROUND) CABLE, THEN WAIT TWO MINUTES FOR THE AIRBAG SYSTEM CAPACITOR TO DISCHARGE BEFORE PERFORMING FURTHER DIAGNOSIS OR SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE AIRBAG SYSTEM. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY.
NOTE: Disassembly of the HVAC housing is not required to remove heater core.
  1. Remove the HVAC housing. Refer to Housing Assembly HVAC/ Service and Repair/ Procedures. See: Heating and Air Conditioning\Housing Assembly HVAC\Service and Repair
  2. Remove the foam seal from the heater core tubes.
  1. If equipped with the Dual Zone system, remove the linkage rod from the actuator levers to gain access to the heater core (Heater Core Dual Zone Shown, Single Zone Typical).
  2. Remove the two screws that secure the heater core tube bracket to the HVAC housing.
  3. Remove the heater core tube bracket.
  4. Pull the heater core out of the HVAC housing.
  5. Inspect all foam seals and repair or replace them as required.
INSTALLATION
  1. Install the heater core into the HVAC housing.
  2. Position the heater core tube bracket onto the HVAC housing.
  3. Install the two screws that secure the heater core bracket to the HVAC housing. Tighten the screws to 2.2 Nm (20 in. lbs.) .
  4. If equipped with the Dual Zone system, install the linkage rod onto the actuator levers.
  5. Install the foam seal onto the heater core tubes.
  6. Install the HVAC housing. Refer to Housing Assembly HVAC/ Service and Repair/ Procedures.
The heater core is located in the HVAC housing, under the instrument panel.
The heater core is located in the HVAC housing, under the instrument panel. It is a heat exchanger made of rows of tubes and fins.
The heater core is not repairable and if damaged it must be replaced.
Engine coolant is circulated through heater hoses to the heater core at all times. As the coolant flows through the heater core, heat removed from the engine is transferred to the heater core fins and tubes. Air directed through the heater core picks up the heat from the heater core fins. The blend door allows control of the heater output air temperature by controlling how much of the air flowing through the HVAC housing is directed through the heater core. The blower motor speed controls the volume of air flowing through the HVAC housing.
The heater core cannot be repaired and, if faulty or damaged, it must be replaced.
Old 11-03-2011, 09:29 AM
joseph7195's Avatar
joseph7195 joseph7195 is offline
Vehicle: 2002 Dodge Ram Quad Cab
Trim Level: basic, but adding on
Rep:26
joseph7195 is on a distinguished road
Great Info^^. It took a while to get the dash off, but it wasn't too bad. I went ahead and took out the front seats(only takes 10 minutes and about 8 bolts) just to make it easier to get tot he dash and to make extra room.
2010 USACI World Finals Champion, 2nd Place Port Wars. 168dbs
Old 11-03-2011, 10:03 AM
Rep:12
cool make sure you take picture cause That is something to be proud of that your doing it yourself.
Old 11-15-2011, 08:24 PM
Trim Level: 1500
thanks everyone problem was solved good thing i didnt have to take anything apart .. Heater core lines warent conected
Old 11-17-2011, 08:44 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
I got pictures of my weekend lol.
Im just waiting on my new dash panels to come in so I can install them, if your dash is cracking and you need to change a heater core, dont expect to be able to piece it back together, it crumbles as you handle it.
Sure it'll suck, but it'll make you a man
Old 11-18-2011, 12:33 PM
440Magnum 440Magnum is offline
Vehicle: 2008 Ram 1500
Trim Level: Lone Star
Rep:26
440Magnum is on a distinguished road
While its THAT far apart, I'd cover the whole dash in Dynomat or some other sound deadener. Great opportunity...
heater core removal 84 ram no air kgl271 Heating & Cooling 2 10-18-2011 12:00 PM
A/C mod & heater core bypass Spartan Heating & Cooling 1 07-07-2011 10:01 AM
Heater Core Replacement Dalton Heating & Cooling 1 02-05-2011 11:10 PM
Big Bang after heater core job Quiet Lunatic 5.9L V8 Specific Topics 5 12-31-2009 07:19 PM
Is this a heater core leaking? over2land V10 Specific Topics 10 07-15-2009 12:56 PM
