Old 11-03-2011, 07:05 AM
bigmikelrg's Avatar
bigmikelrg bigmikelrg is offline
Vehicle: 1999 Dodge Ram 1500 Sport
bigmikelrg is on a distinguished road
Default Applying hp to the ground?
What can I do to get the most hp form my engine to the pavement I know about the ring and pinion I'm getting a set of 4.10 Friday possibly is that the ideal for the track and what else can I do keeping in mind I have a low budget. Thanks guys.
HyperTech Power Programmer, PowerAid Throttle Body spacer, BOSH Plugs, Super40 FlowMaster Exhaust
Old 11-03-2011, 09:01 AM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
1 Don't spin the tires at the line! It may look cool, but trackwise it cost you ET. Get some dedicated slicks or drag radials for track use. Also get skinniest for the front to refuse I sprung weight.
2) LSD or other type of locker
3) practice your launch
4) couple of sandbags in the bed to help weight transfer
Have fun, and good on you for keeping the racing on the track!
Old 11-04-2011, 03:54 AM
bigmikelrg's Avatar
Like what drive train upgrades should I do that r cheap to get all my torque and ho to the pavement?
Old 11-04-2011, 09:03 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
There's not a whole lot that's really cost effective. Best bang/buck drivetrain mods are gearing and torque converter(assuming you're an auto). They are give and take though...
Sean
Old 11-04-2011, 09:38 AM
Rep:24
Maybe get a 2nd job? ( I'm being serious!)
As said above^^ racing isn't cheap. Speed costs if you want to be competitive, even in bracket racing.....
Old 11-19-2011, 05:26 AM
bigmikelrg's Avatar
Yea so what can I do to my drivetrain and transmission to get more torque from my motor to the ground besides ring and pinion and also a locker ?
Old 11-20-2011, 08:27 PM
snrusnak's Avatar
Rep:1385
Basically a better torque converter and gearing are the only somewhat cost effective ways.
Sean
Old 11-20-2011, 08:48 PM
I push the skinny pedal
Rep:3277
Other options are a lighter weight drive shaft, like aluminum or even a carbon fiber one, but those get pricey but are super light so you're not dealing with the spun weight of the steel one.
Kurtis
Old 11-21-2011, 05:34 AM
bigmikelrg's Avatar
Thanks guys those r good starters. Also what kind of torque converter should I get? And if anything else comes to mind leme know.
Old 11-21-2011, 07:50 AM
snrusnak's Avatar
Rep:1385
An alum driveshaft is definitely a plus, same with lightweight (smaller) alum wheels, smaller and lighter tires, etc... Going to an electric fan also would reduce drag and free up a few hp by removing the mechanical fan. As far as the torque converter, it really depends on your application, a higher stall rpm usually helps overall, but sometimes can hurt top end power, so it's sort of give and take. What is the main purpose of the truck daily driver, drag racing, off roading, towing, etc...? You can do some research on google about torque converters.
Sean
Ground Force 2/3 Drop for 4x4's dustin72 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 02-25-2013 09:24 PM
Help! Ground cable issue!! AcombativePYRO 4.7L PowerTech V8 Specific Topics 1 09-05-2011 07:49 PM
Help! Ground cable issue!! AcombativePYRO Electrical 1 09-05-2011 07:39 PM
'10 TRX 2WD More Ground Clearance olegaram 2010 Dodge Ram Forum 4 10-14-2010 05:55 AM
Floating ground Excoastie Dodge Ram General Discussion 2 12-24-2008 10:53 AM
