Old 11-03-2011, 10:21 AM
Antimullet Antimullet is offline
Vehicle: 2009 RAM 1500 SLT 2WD
Color: Gray
Antimullet is on a distinguished road
Default 09 Ram Lowered Now Whining Noise
Hey Guys/Gals,
Lowered my ram only 2" in rear and 3/4 " in the front (Cut Coils).
Not sure if the problem is interrelated or just coincidental, there is a very loud whining now and it seems to be coming from the output shaft area of my transmission.?!?!? It developed a few days after I lowered it.
I thought the rear end was toast its so loud I put it on jacks, ran it and the whine seems to come from the front either the front ujoints or the output shaft bearing maybe?
I jacked it back up to simulate standard ride height before I dropped it and it still whines like crazy.
I did have the rear pinion seal replaced about 6 months ago when I first bought the truck, I havent checked to see if that nut backed off or anything yet.
The driveshaft U joint angles are not extreme to any extent at all.
I'm hoping its something simple like the driveshaft U joints, truck has 68000 miles on it.
Any suggestions? I was going to pull the driveshaft and see if the noise still emanates from the tranny as a first step in troubleshooting.
Its an 09 rear wheel drive SLT Hemi.
Thanks for any input folks!
Old 11-03-2011, 08:02 PM
Color: Gray
No Takers?
I think my rearend is toast. Looks like the stealership didn't set the rear pinion preload correctly when they installed the new rear pinion seal, I can see where they just marked the nut and housing. Driveshat ujoints were fine.
I turn the pinion flange by hand and its rough in two spots like a dang tooth or two is missing.
Whining Noise LCJr Electrical 2 09-20-2011 01:41 AM
Anyone have a whining noise.... BLKSVT 5.7L (345 cu in) HEMI V8 Specific Topics 20 05-07-2011 03:10 PM
whining noise from engine Travis 5.7L V8 Specific Topics 8 02-22-2011 07:34 PM
Whining noise when accelerating thewhitneys1 4.7L PowerTech V8 Specific Topics 6 08-25-2010 08:33 PM
whining noise on decel. argo 5.2L V8 Specific Topics 9 07-19-2010 05:16 PM
