Old 11-03-2011, 08:19 PM
Jackson's Avatar
Jackson Jackson is offline
Vehicle: 2010 Dodge Ram Quad Cab
Jackson is on a distinguished road
Default Engine Fan
Anyone have problems with there engine fan not disengaging? I've been complaining to the dealer about this every time I go for an oil change but since I usually go on Saturday, there is never anyone there to look at it. Basically, it sounds like I am driving an 18-wheeler when I accelerate or downshift out of overdrive. Just curious if there is a quick fix that will get me another 1000 miles until I get it to the shop. I get crap mileage with it engaged. In warmer weather it would occasionally disengage so I didn't worry about. It would stay on for a week, shut off for a week. Now that it is colder, it is annoying me and will not shut off.
The service guys who check me in are never any help. I had to come here to find out about the thump I was feeling which turned out to be no baffles in the 32 gallon tank. Thanks by-the-way. I assume that was the right answer. The individual that responded had the symptom nailed and knew where the gas gauge needed to be when it happens.
Old 11-04-2011, 12:41 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
You're talking about the mechanical clutch fan right? Sounds like an isolated incident I haven't heard anyone else with this issue. What's your mpg been? It should be easy for them to replace it, very easy to replace.
Sean
Old 11-04-2011, 12:43 PM
snrusnak's Avatar
Rep:1385
With stock programming, the electric fan is not programmed to turn on until 222 deg F (unless the AC or defroster is on as he said above).
Sean
Yet another temp gauge question snookomatic 4.7L PowerTech V8 Specific Topics 6 10-31-2011 10:55 PM
2009 Dodge 3500 SeaCaptain 2009 Dodge Ram Forum 4 10-10-2011 02:50 PM
Intake Belly Pan Gasket RamTech Dodge Ram Knowledge Base 2 02-07-2010 05:49 PM
Truck shaking when gas is depressed dirtsurferus 5.9L V8 Specific Topics 12 01-31-2010 02:19 PM
Painting Engine Cover Incognito Dodge Ram General Discussion 15 01-11-2010 11:14 AM
