Back and Forth About 6.1L Intake - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 11-04-2011, 06:20 PM
moparornocar72's Avatar
Rep:630
Good looking out, I appreciate it.
14.268 @ 95 MPH Full Trim
Old 11-07-2011, 08:48 PM
mgh's Avatar
mgh mgh is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
The 4th gens run the same injectors as the 6.1, so you can use the ones you have. The only other thing you may need is a 6.1 MAP sensor.
Old 11-07-2011, 10:13 PM
Rep:630
thanks for the info. i'm still debating and checking the bank account
Old 11-07-2011, 11:51 PM
Rep:3347
Originally Posted by kay9 View Post
Yeah no port adapters needed since you have eagle heads. Also no relocation brackets needed for the AC and Alt either.
You will need to extend your fuel line. I used this
http://www.zex.com/zx/fuel-line-adap...srt8-hemi.html
Also remove the fan shroud to make way for the CAI.
If the manifold does not have a egr then you will need to block off yours (if you have one).
Maybe look into 6.1 coil covers to hide the wiring and make it look pretty.
I would say all the same here, and if you can get the manifold at a great price then this would be a great thing to hold onto until you have a few more go-fast mods done. I am in the process of the same swap with eagle heads on my 3rd gen. I recommend blocking off the EGR anyways, a kit from BT cost very little, and I would also look at a set of either the OEM coilcovers, or better yet a set of covers from 3GCustoms.
If you're looking for a good intake for the manifold I would highly recommend looking at the LegMaker intakes, they are top notch and high quality, plus, being carbon fiber, they do not need to be supported the way traditional intakes are, as they weigh almost nothing and from many LX owners they are the most popular. I personally bought a hammer style intake from LMI, but if you're on a slightly smaller budget, then you can do the FrankIntake IV and still get the performance.
One thing to be aware of, is the 6.1L manifold will reduce your bottom end compared to the 5.7L, but will definately free up the top end. A higher stall converter and/or cam will help you get the bottom end back up, but you need to match the build properly.
Old 11-07-2011, 11:56 PM
Rep:630
can someone take some overhead pics of the whole intake on the truck? I would like to see what it looks like from the topside. any help would be greatly appreciated
