Old 11-04-2011, 06:10 PM
VvgrovervV's Avatar
VvgrovervV VvgrovervV is offline
Vehicle: 11' Ram Sport
Color: Blue
Rep:21
VvgrovervV is on a distinguished road
Default Tranny problems already.
well on my way out wed. night to get some food my truck felt like someone rear ended me. I looked around and nobody there then found my transmission was stuck into 4th gear. I tried to pull over turn off the truck reset it and restart and still stuck then the check engine light came on. Long story short I just got my truck back from the dealership where they had to replace the valve body inside the tranny.
My truck only has 4500 miles on it. I will keep my fingers crossed and hope it don't happen again.
Old 11-04-2011, 09:51 PM
Old Dodger's Avatar
Old Dodger Old Dodger is offline
Vehicle: 2006 Ram Cummins SLT
Rep:28
Old Dodger is on a distinguished road
The used to say, "sounds like you lucked out with a trany built on a Monday after a weekend of booze!" Or something like that. I have to wonder if the dealer might get an OK to just replace it with a new one. Hope you keep us posted.
Old Dodger Rol Extreme SW MI
SUPERCHIP CORTEX PROGRAMER BESTOP POWER BOARDS PERAGON BED COVER S&B INTAKE BACKUP CAMERA My Favorite Cargo, CASE & INGERSOLL GARDEN TRACTORS AND EQUIPMENT
My Song, http://www.tomrush.com./video_remember.html
Old 11-05-2011, 12:52 AM
Rep:2640
actually it sounds like they didn't get all the machining debris out of the valve body
these Electronically controlled transmissions go into LIMP MODE, 4th gear easily.
That is the main reason they recommend changing fluid at the interval that they have
Besides the valve body, the only other part the may cause trouble is the torque converter & i think they got a handle in it as well
Old 11-05-2011, 06:52 PM
VvgrovervV's Avatar
Color: Blue
Rep:21
so far i have put a 100 miles since i got it back from them and the truck is running fine now.
Now just pulling my hair out trying to get my HID's to work right which is a whole-nother thread in itself.
Old 11-06-2011, 03:16 PM
Razorback's Avatar
Razorback Razorback is offline
Vehicle: 2011 Ram Crew
Color: Deep Cherry
Razorback is on a distinguished road
Left work Monday morning and my truck felt like a slug leaving the parking lot. Look down and see 4th gear. Wouldn't come out. Drove straight to the dealer and they promptly reflashed the tranny. Said there were 2 "pending" error codes that hadn't been "activated" yet, ???, one for a valve body and one for temp (it was stuck at 44 deg on the tranny tenp indication). This was at 1600 mi, TC replaced at 1300 mi.
Growing old is inevitable, growing up is optional.
Old 11-06-2011, 03:39 PM
VvgrovervV's Avatar
Color: Blue
Rep:21
haven't experienced the torque converter problem yet but i got my ears open for it which is hard to hear over the magnaflow exhaust
Old 11-06-2011, 10:20 PM
cudase's Avatar
cudase cudase is offline
Vehicle: 2011 Dodge Ram
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:53
cudase will become famous soon enough
Good Luck with this one. I wish I would have traded mine in when my issues first showed up. I had to have the valve body cleaned in 1 week of owning the truck, the trans rebuilt within 6 months of ownership and again 1 month later because the dealership was incompetent. I am still having shift issues and it looks like the transmission is going to have to come out again. I am hoping to absolutely destroy it this winter pulling my snowmobile trailer so they just replace the whole thing rather than try and rebuild it again. The dealerships around here cannot rebuild a transmission to save their lives.
Old 11-07-2011, 07:55 PM
Old Dodger's Avatar
Rep:28
I would contact the factory and request a replacement with the next issue. sounds to me like you have had about all one should need to put up with!
Old 11-07-2011, 09:47 PM
5.7ram's Avatar
5.7ram 5.7ram is offline
Vehicle: 2010
5.7ram is on a distinguished road
Make :DODGEModel :RAM 1500Year :2011Build Dates :2009-09-01 - 2010-12-31NHTSA CAMPAIGN ID Number :10V656000Date Owner's Notified:2011-04-04Date Received by ODI:2010-12-24Date Added to Database:2010-12-29Manufacturers Involved:CHRYSLER GROUP LLCManufacturer's Responsible for the Recall:Manufacturer Campaign Number:K36Component:SUSPENSION:REAR:AXLE:SPINDLEPotential Number Of Units Affected :60382Summary:
CHRYSLER IS RECALLING CERTAIN MODEL YEAR 2011 RAM 1500 TRUCKS MANUFACTURED FROM SEPTEMBER 2009 THROUGH DECEMBER 2010. SOME VEHICLES MAY HAVE EXPERIENCE A NOISE "GROWL, GRIND" COMING FROM THE REAR AXLE BEARING WHICH COULD EVENTUALLY SEIZE.Consequence:
A FAILURE OF THE BEARING COULD CAUSE THE VEHICLE TO STALL INCREASING THE RISK OF A CRASH.Remedy:
CHRYSLER WILL NOTIFY OWNERS AND WILL INSTALL AN OIL PORT INSERT INTO THE REAR AXLE FREE OF CHARGE. THE SAFETY RECALL BEGAN ON APRIL 4, 2011. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.Report Initiator:MFRV ReportRegulation Part Number:Federal Motor Vehicle Safety Standard Number:Notes:
OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 'TTY 1-800-424-9153', OR GO TO HTTP://WWW.SAFERCAR.GOV .
2011 Dodge Ram CC Sport Hemi. / 4300 Hid's Top & Bottom / Tints / 24' Kmc Slide's w Toyo's / BellTech 2/4.
Old 11-07-2011, 09:58 PM
I don't think this recall ^^^^ applies to the problem stated.
Electrical / Tranny Problems AMJA ONE 5.2L V8 Specific Topics 2 04-19-2011 01:01 PM
High Idle RPM, and (maybe) tranny problems? greenmachine16 5.9L V8 Specific Topics 0 11-25-2010 03:47 AM
standard tranny problems apcdrewie420 5.2L V8 Specific Topics 3 05-26-2010 02:44 PM
04 ram 2500 tranny problems!!!! HELP!!!!!!!!!!! ramman23 5.7L V8 Specific Topics 4 05-01-2010 01:14 PM
Tranny Problems prixgt8 4.7L PowerTech V8 Specific Topics 5 12-03-2009 10:33 AM
