Old 11-05-2011, 01:05 AM
LuckysHemi LuckysHemi is offline
Vehicle: 2011 Ram 1500 SPORT CC
LuckysHemi is on a distinguished road
Default Gear sway 09-12 1500 Hemi
Hello i was just thinking about my truck could use a little more bottom end power. My 2011 1500 hemi already has the LSD 392 rear end. But what do you guys think of the 410 gears? I dont want to run the 456 because i do alot of freeway driving with my truck and i dont really want a big change in RPM at crusing speeds. What do you guys think
Old 11-05-2011, 01:17 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
3.92's to 4.10's isnt worth it..too close. the logical next step is 4.56's. what size tires are you running now. i run 31" 17's and my mileage is very good for 4.56's...
Old 11-05-2011, 01:51 AM
I just think after doing the math the 456 would change my rpm's a lot. I also have the stock 20" sport wheels. Thanks
Old 11-05-2011, 04:01 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:605
Think 4.10's are the lowest you can get for the 11's.
Old 12-15-2011, 09:44 AM
nick.gauv's Avatar
nick.gauv nick.gauv is offline
Vehicle: 2006 dodge ram 1500 hemi
nick.gauv is on a distinguished road
how big of a difference did the 4.56 make on the track(1/4)
Old 12-15-2011, 09:48 AM
sethmark sethmark is offline
Vehicle: 2009 Ram 1500 SLT
Rep:19
sethmark is on a distinguished road
Remember that the lower the ratio the less pinion to gear you have. It most likely won't make much difference, but if you're looking at tracking the truck, you want the most tooth to tooth contact possible.
Frankly a tighter wound torque converter might yield a better time at the strip.
2011 dodge ram 1500 hemi regular cab 4x4 semichigan Dodge Ram For Sale - Used Dodge Trucks 4 11-09-2012 03:50 AM
5.7l Hemi in a 2500 the same as a 1500?? VonLuck Dodge Ram General Discussion 16 07-10-2011 02:58 PM
Leveling 2005 Quadcab 1500 2wd Hemi silverd Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 07-07-2011 09:00 AM
03 1500 Laramie hemi! Irish Newbie Checkin! 10 12-20-2010 12:27 AM
Need performance help with 04 Ram 1500 5.7L Hemi 04 hemi Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 12-30-2008 05:10 PM
