Old 11-05-2011, 08:16 PM
Dieselkiss's Avatar
Dieselkiss Dieselkiss is offline
Vehicle: 99 Ram 1500
Trim Level: ST - Very Base Model
Color: Red with grey
Rep:48
Dieselkiss is on a distinguished road
Default 3rd Gen Light on 2nd Gen
Hey guys, I've been thinking about fitting 3rd gen headlights (and maybe tail lights) to my 2nd gen Ram for a while now. I like the way the 3rd gen lights look and honestly think the 2nd gen lights/front end is starting to look a little dated.
Now I know I'll have to change the bumper too because of the dips for the 3rd gen light which will involve making custom mounts, and am pretty sure I may also need to re-shape the front of the wing to accommodate the larger lights and all that is fine - in fact I'm actually quite excited about doing that kind of stuff.
BUT...
My question is.....are there any electrical issues with doing this change?
I know the actual plugs may be different, but I was more concerned about load issues on my electrical system because am not sure what bulbs the third gen uses. Anyone know if my electrical system could handle 3rd gen lights?? Or if there are any electrical mods I'd need to make regarding loads/fuses???
Old 11-08-2011, 01:36 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
04 headlights and fenders not sure on what other fabrication
Old 11-08-2011, 10:04 AM
Dieselkiss's Avatar
Rep:48
Nice, that looks good. Be cool to know if he had an issues with load on the electrical system. I'm guessing probably not, but one never knows.
Old 11-08-2011, 10:16 AM
Rep:1930
Yeah I wouldn't think so either.
Old 11-09-2011, 08:43 PM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
i wouldnt think so as your pretty much only changing the cosmetics
Old 11-09-2011, 11:18 PM
Vehicle: N/A
Rep:1045
heres the entire bulb guide for the 02-05 rams with which youll be using the headlamps
http://www.sylvania.com/ConsumerProd...RG-Results.htm
High & low beam headlamp
9007
9007SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9007ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9007EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9007XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9007CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
while most of that is extra noise... the headlight on 02-05 rams use a 9007 bulb, which has identical mounting points as the 9004 bulb, which is what is in our second gen. so logically speaking, you should have NO electrical issues with your headlamps
on another note... if the plugs (tails) dont fit the 3rd gens or even the front turn signals, lmc truck sells all the plugs
Old 11-12-2011, 04:03 PM
Dieselkiss's Avatar
Rep:48
Thanks for all he advice guys.
double0ram, thanks for taking the time to post that info, that really helps.
When I get around to doing it...which may be sometime....I'll post a step by step account with pics and let y'all know how it went.
Old 11-12-2011, 04:46 PM
Vehicle: N/A
Rep:1045
No problem. I use that site a lot for reference. Looking forward to seeing this project! The 9007 and the 9004 are almost identical and the plugs are identical. In an hid kit I used 9007s for mine actually...
Old 11-14-2011, 07:17 AM
Dieselkiss's Avatar
Rep:48
That's actually given me a thought I hadn't considered.
I'd thought about upgrading the HIDs with the stock lights, but might be nice to upgrade to the 3rd gen and then do the HID upgrade as well. Hmmmm, the plot thickens lol
Old 11-15-2011, 11:53 AM
Vehicle: N/A
Rep:1045
hids are awesome. i will never own another vehicle without a set. i put them on my ram, loved em so much that i put em on my wifes 300
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 08:19 PM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 12:59 AM
Check gauges light came on 06Daytona Electrical 4 08-24-2011 12:21 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
Engine Light update kgb503 2010 Dodge Ram Forum 4 01-31-2011 08:25 PM
