Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 11-06-2011, 08:38 PM
2kram 2kram is offline
Vehicle: 2000 ram 1500
2kram is on a distinguished road
Default rear shock bolts suck
title says it all... upper shock nut and bolt defeating me. I read somewhere that the nut is factory "welded" to the frame? I soaked it w/ penetrating oil for 2 days and still cant get it to budge. Not really any room for a breaker bar to access the bolt. Any ideas guys??
Old 11-06-2011, 08:43 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
If it is safe enough to get to with a torch or even a heat gun, i would heat the nut so it expands then loosen the bolt. Put some anti seize on the bolt when you re-install to prevent it from rusting together again.
If you can't run with the Big Dogs, Stay on the porch.
Old 11-06-2011, 08:54 PM
Rep:2804
WD-40 won't work, if that is what you used, it is not really a penetrant
Liquid Wrench is only a bit better
PB BLASTER is better than both of them
KROIL that you can buy at most gun shops works really well
Sometimes you just need to add heat, using a propane or Mapp gas torch
http://www.bernzomatic.com
Old 11-06-2011, 09:35 PM
I used on day 1, PBblaster. Day 2, break free. Impact gun won't budge it either. I think you're onto something with the heat. Worst case senario..... TNT. lol
