Door Rust - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Rust Repair
Rust Repair Fighting Mother Nature!
Old 07-06-2011, 12:06 AM
2001RAMSPORT
Default Door Rust
I have a 2001 Dodge Ram Sport that is starting to rust on the bottom of the doors and needs some patching up. Did anyone paint or rhino line theirs and have any pics or advice. It is not that much rust that I need to replace the door and I may be able to sand and paint if I can find Duplicolor paint to match it. Any suggestions at all will help.
Thanks in advance
Old 07-06-2011, 09:24 PM
What I'd do is make sure that, after you have done some sanding but prior to priming, is that the rust won't spread. So get a spray or brush on rust inhibitor and apply that first.
There are sites that have matching paint in rattle cans that are of good quality. All you need is your truck's paint code.
Old 07-08-2011, 11:21 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
This is some great stuff that I have seen used on old jeeps to stop the rust from spreading, like MADDOG was suggesting.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 07-09-2011, 04:52 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
POR-15 is amazing stuff! In my car, before I got the truck, I had a leak and my whole was soaked and when I ripped the carpets out I noticed rust, I was apart of a different forum and they suggested POR-15, so I used that on my whole floor, let it dry properly, and the stuff is amazing, prevents rust so good, never had a issue after.
Old 07-09-2011, 07:39 PM
Jmorris Jmorris is offline
Trim Level: SLT Big Horn
Rep:25
Jmorris is on a distinguished road
I had mine linex'd. heres some pics
http://www.ramforumz.com/showthread.php?t=84806
2010 White Ram 5.7 1500 QC 4x4 Big Horn
raptor 4" tube steps, rockers linex'd, egr bug shield
Old 08-04-2011, 08:17 AM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
i've seen that on a number of that gen Ram. any word of the cause? usually there are plastic plugs at the bottom of the door and if you don't pull them out water collects. i was checking the other day and didn't notice any plugs, unless i missed them. does anyone know if there's a drain at the bottom of the door? thanks.
2011 Ram 1500 Express, RCSB, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Debadged.
2017 Ram 2500 Tradesman, CCSB, Cummins, Blue Streak, MBRP DPF back pipe, K&N drop-in.
Old 09-12-2011, 11:35 AM
Rep:19
found a small opening along the bottom on the side with the door handle. you'll need to have the vehicle on a slight incline upwards to fully drain. the opening is enough to get a straw from a rattle-can inside and spray some protection in there.
