Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 11-08-2011, 04:26 PM
matthcummins matthcummins is offline
Vehicle: 2005 dodge ram diesel
Color: purple/grey
matthcummins is on a distinguished road
Default long start ....
Hi , my 2005 cummins when I start , it's take 5-6 turn of crank to start...Glowplug are good and I hear the fuel pump under the cab....I have a 98' cummins and it's start a 1/4 turn.If someone could help.... Fuel filter???? fuel pump in tank?????? injector?????
thanks
Math
Old 11-08-2011, 06:06 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Well your glowplugs are junk cause cummins have grid heaters lol
Have you had your batteries checked out? Still have the stockers in the 05 and they are on there way out which gives a slow start when it sits for a day or two.
If its turning over fine then its a fuel air problem. I would start at the fuel filter and make sure you are getting good fuel to it
Old 11-08-2011, 06:49 PM
Color: purple/grey
the batteries are good , because he's not turning slowly . Is the fuel filter easy to replace? And is it hard to purge?
Old 11-08-2011, 09:50 PM
Color: Mineral Gray
Rep:177
Fuel filters a breeze. Its on the fire wall on the drivers side, you'll see a black canister the looks like it has a large nut on top and has a yellow valve on the bottom. Just open the valve (with something underneath if your trying to be clean and of course you dont want to hurt the enviroment...) and the filter will drain. Then just unscrew the top from where it looks like a nut (because thats what it is haha i forget the size though) unscrew and pull the filter out. Reverse.
When you done make sure the valve is shut. To reprime get in the truck and turn the key to the on position and leave it for 20-30 seconds, repeat 5 times and the truck will be ready to start
Old 11-09-2011, 11:12 AM
Color: purple/grey
Ok good, if the fuel heater is open circuit, check engine will be ON????
