Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Old 11-06-2011, 06:16 PM
danimal danimal is offline
Vehicle: 2005 Dodge Ram
danimal is on a distinguished road
Default Rear axle mod
i am thinking of adding a new rear axle cover so i can add more gear oil, and i am thinking of adding a temp gauge as well
i have a 2005 ram 1500 4x4 5.7L that i use for towing a 5th wheel
has anyone done this mod ? would it be worth the $300. +
so far i have not noticed a overheating problem but the longest trip was around 350 miles with very few hills
if so where did you buy the temp gauge ?
dan
Old 11-07-2011, 05:17 AM
ram71351's Avatar
ram71351 ram71351 is offline
Vehicle: 2014 Dodge Ram Laramie
Color: Black Gold Pearl
Rep:45
ram71351 is on a distinguished road
Not a bad idea .... sure someone will be along to help. Here's a bump for you.
Old 11-07-2011, 02:58 PM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2004 dodge ram 1500
Rep:31
charlieb is on a distinguished road
yeh good idea when towing heavy equipment,hold almost double fluid capacity.oasis has a good 1 ebay 200 or less.same as magtech selling for 400.00.i dont think wasting too much on a temp gauge unless you can do it yourself reasonable.
Old 11-07-2011, 03:07 PM
Rep:2642
Which ever cover that you decide to get, get one with a magnetic drain plug
I never did understand why you should have to pull the whole cover just to drain the fluid, the metal shaving or chunks will stick to the magnet, if there is more on it than you would like to see, then you can pull the whole cover. Save time & get the magnetic screw in drain plug
Old 11-07-2011, 03:38 PM
thiggins's Avatar
thiggins thiggins is offline
Vehicle: 2012 Ford F150
Rep:44
thiggins is on a distinguished road
I just installed a Mag Hytec cover on mine after a rear end rebuild. I'm very happy with it so far. It has all the stuff you're talking about, and looks awesome.
Don't know about the temp gauge, but I'll bet you can email Hytec and they can tell you where to get one.
Old 11-07-2011, 04:02 PM
Rep:2642
They may even carry the temp fitting, on the site it reads:
http://www.mag-hytec.com/differential.htm
1/8 NPT temperature sender port
Old 11-07-2011, 04:48 PM
I have done it with another truck and it was well worth the money. $300 is cheap compared to overheating and seizing a differential!
I actually got the axle cover, hardware and gauge from a local RV dealer.
