took dash out and now speedo,odo,cruise,and fuel calculator dont work. help! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 11-08-2011, 09:36 PM
70scout800 70scout800 is offline
Vehicle: 1999 dodge ram
Trim Level: slt 4x4
Color: blue
70scout800 is on a distinguished road
Default took dash out and now speedo,odo,cruise,and fuel calculator dont work. help!
i recently took my dash out and changed heater core. after reassembling my speedometer, odometer, fuel calculator, and cruise dont work. the only thing i see out of place is a green female connector, next to the main harness with the bolt through it. i can not find a male end anywhere, and sadly cant remember if there was one. any advice would be appreciated.
Old 11-08-2011, 10:15 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
did it blow a fuse?
Old 11-08-2011, 10:22 PM
Trim Level: slt 4x4
Color: blue
i checked instrument A and B fuses. they were good. couldnt find a speedo fuse. any others i should check? does anyone know what this green female connector is for? it is under driver side dash besides the main harness plug
Old 11-09-2011, 04:40 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
I d say if it has a bolt in ground it see what happens. What do you have too loose.
Old 11-09-2011, 04:51 PM
ramfam's Avatar
Rep:21
Sounds too me you back lights and warning lights might not work ether. and if the wire comes off from pcb where the harness hooks up thats the only thing it could be. Let us know.
Old 11-09-2011, 08:28 PM
Trim Level: slt 4x4
Color: blue
back lights work. what is the pcb? thanks
Old 11-10-2011, 09:49 AM
ramfam's Avatar
Rep:21
Printed curcit bored that runs the back of dash. Now have you found the other end of the wire?
Old 11-10-2011, 04:47 PM
Trim Level: slt 4x4
Color: blue
thanks, you talking about the two plugs behind instruments? right. not found wire yet, been bad weather. im gona search more it must have gotten lost when i put thedash back in. im sure the wire harness is the problem unless its a harness not used on my truch, then im looking for something thats not there.
Old 11-10-2011, 04:50 PM
Trim Level: slt 4x4
Color: blue
im gona look for male end of harness and pull instrument cluster back out and make sure its connected good. i will let you know what i find
Old 11-11-2011, 02:39 PM
ramfam's Avatar
Rep:21
Eletric grimlens suck. Take your time retrace your steps it will turn up
