Old 11-23-2011, 11:55 AM
70scout800 70scout800 is offline
Vehicle: 1999 dodge ram
Trim Level: slt 4x4
Color: blue
70scout800 is on a distinguished road
ok, i looked real good and on top of the blue plug is labeled aux. brakes. must be for trailer brake options. so that is ruled out now. i also did the cluster check and all gauges, including speedo worked. so now im really stumped. only thing i can think of is a big coincidence that the speed sensor went bad at same time i took dash out.
if my speedo worked with cluster check then grounds must be good, right?
Old 11-23-2011, 10:42 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
if the check worked the cluster is working but there is something a miss there are 3 points that this thing has connections according to haynes book? and if check eng light not on speed sensor should be sending sig to computer.
Old 11-23-2011, 10:50 PM
ramfam's Avatar
Trim Level: Base
Rep:21
trust me warlock sport is far from mine I have no power anything just ac cruise tilt 318 5 speed as well.I dont even have cloth inserts on the doors. lol but thats the way I want it nobody in my house will drive it but me
Old 11-24-2011, 07:23 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Lol, mine either and that's the way I wanted it...less to go wrong...less to fix.
It's a classic example of less is more. I do have the 2/75 A/C though. Roll down 2 windows and do 75.
No cruise, no tilt. The only things on mine that start with power are brakes and steering.
Old 11-24-2011, 07:28 PM
Stainless's Avatar
Stainless Stainless is offline
Vehicle: 2011 Dodge Ram
Color: Bright white
Rep:13
Stainless is on a distinguished road
Pic of the plug that isn't plugged in?
Old 11-26-2011, 01:40 AM
Trim Level: slt 4x4
Color: blue
i changed rear speed snsor and it made no diffrence. not sure what to try next. sensor code was on, i will have to check tomorrow to see if its gone
Old 11-26-2011, 10:28 AM
ramfam's Avatar
Trim Level: Base
Rep:21
ok so we know the computer had no sig from sensor so lets try this is the sensor its self geting power? you know dash, computer have power you need to look and see where the speed sensor runs check all of the wire, grounds. like the manual shows there are 3 points that have conection. the only bad thing is the diagram that they give you in the book has no flow to it at all. it confuses the hell out of me and I kind of know how to read these things!
Old 11-26-2011, 10:43 AM
ramfam's Avatar
Trim Level: Base
Rep:21
what code are you geting should be code po 500 to 503 if you have the manual the check for speed sensor is sec 6-32 step#65 you will need a good volt meter. if there is a prob with the sig comeing from computer see if you can get a better diagram from dealer or if you listen to the book (last resort) take it to dealer.
Old 11-26-2011, 06:07 PM
Trim Level: slt 4x4
Color: blue
ok code p0500 is still showing. got a sensor for tranny but hant installed yet. i guess if that doesnt work, stealership bound iam! i will check and make sure i have power at rear sensor also.
Old 11-27-2011, 10:53 AM
ramfam's Avatar
Trim Level: Base
Rep:21
so its showing malfunction. well thats a start. wish you luck. let us know what I hope will be a final solution. or if you need more help.
