1998 left turn signal starts wiper motor - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 11-10-2011, 02:04 PM
cbs440 cbs440 is offline
Vehicle: 1998 Dodge Ram 2500 Diesel
cbs440 is on a distinguished road
Default 1998 left turn signal starts wiper motor
When I turn the left turn signal on, or the emergancy flashers on, the wiper motor comes on low speed. I have tried new multifunction switch and a new ctm...neither helped or changed anything. Any help would be appreciated.
Old 11-10-2011, 03:05 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
Do you have tilt steering?
Old 11-10-2011, 05:52 PM
I never use it, but yes, I do have tilt steering
Old 11-11-2011, 02:35 PM
ramfam's Avatar
Rep:21
Find a wire diagram start looking for a possible short between 2 wires or bad ground.
Old 11-21-2011, 10:02 PM
Found a bad ground on front left turn signal harness....connected to a good ground and solved problem.....took a lot of figuring, looking at wiring diagrams and searching though
Old 11-21-2011, 10:31 PM
ramfam's Avatar
Rep:21
so it sounds like it back feed through the switch. and the wiper motor had a better around then the signal. I'm glad that you found it.
Old 12-05-2011, 01:04 AM
Mr Wilson Mr Wilson is offline
Vehicle: 1998 Dodge Ram 1500
Color: Black and Silver
Mr Wilson is on a distinguished road
I also have the same problem. Checked all the grounds in the vicinity of the left signal light and have replaced the multi function switch and have not managed to fix the problem. Any suggestions?
Old 12-05-2011, 03:02 PM
ramfam's Avatar
Rep:21
It dsnt have to be just ground for signal lights. Could be ground on wiper or switch itself.
Old 12-15-2011, 12:01 AM
Still looking for a solution
Old 12-15-2011, 12:04 AM
Now wipers coming on when tooting the horn????
