Old 11-11-2011, 12:07 PM
DirtyD's Avatar
DirtyD DirtyD is offline
Vehicle: 03 2500
Color: Gray
Rep:45
DirtyD is on a distinguished road
Default looking to lift my dodge
Well since tax time is about to be coming up, I am looking at lift kits, My goal is 37x13-17 Toyo Open Country M/T. I am running 305-70-17 right now with no rubbing. So with a 6" lift could I run the tires i want with no rubbing? This is a DD/ toy hauler, and sometime i go pull ppl out of the mud.
Feed back and pics would be great
03 2500 ( Hemi ), 8" lift and 38" Toyo Open Country M/T
Old 11-11-2011, 01:55 PM
Yup, with a 6" lift you should have no problem with the tire height but going to a 13" wide tire may cause some rubbing inside at full steering lock.
Your 305 tires are somewhere around 12" wide, probably 2/10ths over that.
Remember, if you are using a mud and snow tire, the actual tire width is usually a bit more than the designated number would lead you to believe. For instance, a Toyo Open Country M/T in a 37X13.5R17 is actually 14.6" wide.
So check your inside clearance!
