Old 11-13-2011, 11:48 AM
1tonwhitey's Avatar
1tonwhitey 1tonwhitey is offline
Vehicle: 2004 ram 2500
Color: slt laramie
1tonwhitey is on a distinguished road
Default 2001 ram 1500 runs rough only on first start up???
Hey all newbie here and I got a problem I cannot get figured out.I rescently bought my first dodge ram a few months ago.A 2001 ram 1500 ext cab 4x4 with 5.2 and 5 speed stick.The truck ran great up until colder weather started coming.It will on first start up run really rough and sputter out only when theres frost or moisture in the air.I have replaced o2 sensor,cts,acs,cleaned throttle body ,new iac.new cap rotor wires and plugs,new battery and cleaned all grounds and connections,The truck runs absolutely perfect once the first start issue goes away.I have to start it let it run rough for a few minutes.Shut it down to sit for a while and restart it and it runs perfect.I am at a loss and I don't want to keep throwing parts at it as my wife is telling me to sell it..lol..It is a great truck other than the cold start issue It has 136 k on it and going by how dirty the throttle body was it was prolly neglected .Would a bad pleneum gasket or egr cause this??I am working on it today and would really like to get this issue fixed before the real cold weather sets in.Thanks for any advice in advance and this is a kickazz site!!
Old 11-13-2011, 05:23 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Check vacuum, shoot wd 40 at base of tb, see if it bogs down, try and ajust idle if those fail. The truck should run around 550 to 700 when warm.
Old 11-13-2011, 06:01 PM
That's a good suggestion ^^^^ and I'd also look at the EGR valve.
Old 11-13-2011, 08:02 PM
1tonwhitey's Avatar
Color: slt laramie
I spent a good portion of the day trying to figure it out I recleaned the throttle body and checked everything again.I had a cel and code p1391 manufacterer controled ignition.But after a while it it turned off.Would a bad throttle body gasket cause this?Also assuming the plenum gaskets have never been changed could that cause it also? Thanks again for any advice,,
Old 11-13-2011, 09:39 PM
Vehicle: N/A
Rep:1045
the throttle body gasket.. mabye. you have vacuum lines running into the throttle body, so its possible. that gasket is no more than 5 bucks at any auto shop. if you havent already, check the vacuum lines. they can easily cause idle issues if they are cracked or not attached for that matter.
Old 11-13-2011, 09:51 PM
1tonwhitey's Avatar
Color: slt laramie
Im gonna get a new one and try it out.I hope that is the problem as I am stumped on this.I have been reading many posts on similar problems and some point to the cps .Ill be glad to get get this fixed so I can share info to anyone out there having this aggrivating problem..Thanks again ..
Old 11-14-2011, 12:03 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Reading one of your last post's im thinking its the eletric spark control on distrbutor not advaceing timeing try. Vacuum test first then go electric. Bad part about it is I dont think its a separate part from distrbutor? Dont know though. Still learning about these trucks. My knowledge is more gm based.
Old 11-14-2011, 07:50 PM
1tonwhitey's Avatar
Color: slt laramie
Well I put in a new throttle body gasket and its still acting up.I Looked into the plenum and saw no oil pooling in there so Im assuming that the plenum gasket is not blown.I searched almost every thread here about similar problems and it was mentioned that the crank position sensor could be the culprit so Im gonna try that next.Ram fan Thanks for the advice and I hear ya on the gm thing.Ive owned 2 fords and about 25 gm trucks and I also am very familiar with them but this is my first dodge and Im starting to wonder what the hell I was thinking???lol I do like the dodge as it drives like a truck Im used to ifs and the dodge just feels stout and badazz .But I cant seem to get this damn thing to run right.Ive been working on it since the day I bought it about a month now. So far I put a new rear diff new transfer case output bearing and seal.New muffler new front wheel hubs and calipers and brakes and brake lines.As for the engine almost every sensor is new new battery new gasket new plugs wires cap rotor etc.It should run great now but its got this damn cold start idle issue thats driving me nuts.Im gonna put the new cps in and pray it fixes it.Im gonna have to remortgage my house and dip into the kids colledge funds soon to get this truck running right..lol I will post up my results and let yous know if it worked.But please for the love of god if anyone knows why my dodge is posessed please HELP!!!!!!!
Old 11-14-2011, 11:03 PM
ramfam's Avatar
Trim Level: Base
Rep:21
I know they can make you crazy. This is my 4th dodge, only 2nd truck but the first with the magnum they seem to be a different animal altogether.
Old 11-15-2011, 12:22 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
The P1391 code often results from a faulty crankshaft or camshaft trigger sensor. Before you go and spend more $ on sensors, check the crankshaft & camshaft trigger sensor wiring.
brad
Interested in one of my mods?
