Old 11-13-2011, 03:46 PM
chaccof chaccof is offline
Vehicle: '05 Quad cab, 4.7l 4x4
Trim Level: Standard
chaccof is on a distinguished road
Default Replaced Rear Diff Pinion Seal
I replaced the rear differential pinion seal this morning. Seemed to go okay and believe I got the pinion nut seated to the same depth it was before I took it off. Used the marks I made, re-installed the drive shaft and have been out for a couple of spins. Doesn't appear to be leaking fluid any more.
Besides the new seal leaking is there anything else I should be on the look out for if I did something incorrectly? It could be my imagination but I thought I felt a very slight vibration - would that indicated that I didn't get the drive shaft seated properly to the pinion flange? Or not in the same position it was before I unbolted it?
TIA for your thoughts.
Old 11-21-2011, 03:51 PM
as an update, the new seal is leaking as it turns out....I'll tear it apart this weekend to see what happened. I'm confident it's seated properly. I did notice that the end of the pinion flange (that fits into the diff) had two 1/8 wide lines that were more worn than the rest of the pinion. They did not feel markedly lower than the surrounding metal though - they were not gouges.
Old 11-21-2011, 04:23 PM
Rep:2657
It seems like several people have run into this issue
http://www.google.com/#hl=en&cp=22&g...w=1024&bih=550
Old 11-21-2011, 06:00 PM
Rep:4072
Yep, had my seal and yoke replaced twice under warranty. Hopefully the last fix is going to hold.
