ZDOG
Old 11-14-2011, 03:27 PM
llsht14's Avatar
llsht14 llsht14 is offline
Vehicle: 2015 Ram Power Wagon
Rep:25
llsht14 is on a distinguished road
if you have a 2011 there are no aftermarket lsd or locker for it, nor is there aftermarket gears if you have the ZF rear end, im stuck in this same situation, only way you can get a lsd is have dodge put in the factory one
2011 Ram 2500 Laramie Megacab Cummins, afe intake, h&s egr delete, flo pro 5" turbo back exhaust, 6 in tip, mini maxx tuner
Sold--- 2011 Ram 1500 Sport
Old 11-14-2011, 04:37 PM
herc herc is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
herc is on a distinguished road
Originally Posted by 916Timmy View Post
Not necesarily...my 3.21 open spins both tires sometimes...The best way is to jack the rear and spin one tire. If the other side goes the opposite direction = open diff. If they spin the same direction = LSD
I totally agree on your first point. As long as you punch hard enough to break both loose at the start, both will spin on an open diff, but one side will likely be longer than the other.
I disagree on your second point. An LSD still has the same basic gearing geometry as an open diff, and both sides still can turn at different speeds. On the jack, the only way that they'd both turn in the same direction (on either diff type) would be if you could also get the driveshaft turning. Otherwise, it'll be opposite directions for the LSD just like the open.
I believe that a true locker (that's actually locked) WOULD do what you say, but again the driveshaft would have to be turning as well, so you'd have to be in neutral.
Old 11-14-2011, 06:26 PM
JoeBlow JoeBlow is offline
Vehicle: 2015 Ram 1500 Laramie
Trim Level: Laramie 4x4 crew
Color: deep cherry red
Rep:6
JoeBlow is an unknown quantity at this point
I'm almost positive the gearing options (3.21 OR 3.92) are a $50 option, the LSD option is $325.
snursnak, not according to my window sticker. I got an slt crew, maybe it's different on other models, but on the options it shows $325 and lists:
3.92 Rear Axle Ratio
Anti-Spin Differential Rear Axle
That's why I assumed the 3.92's came with lsd.
Old 11-14-2011, 06:42 PM
lowrpmtork's Avatar
lowrpmtork lowrpmtork is offline
Trim Level: Sport Crew Cab 4x4
lowrpmtork is on a distinguished road
Got a welder? Hehe!
2011 Ram 1500 Sport Crew Cab 4x4
Yeah, it's got a Hemi...
Old 11-14-2011, 07:40 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Well I just know if you build a truck on the website that's how it is...
Sean
Old 11-14-2011, 07:44 PM
HeyBrownDog's Avatar
HeyBrownDog HeyBrownDog is offline
Vehicle: 2011 Dodge Ram Quad Cab 4x4
Rep:20
HeyBrownDog is on a distinguished road
Took me a while to find a Sport with the LSD. Seems like many dealers weren't ordering them on their trucks, but I got one with mine. 3.55 gears and LSD, but the confusing part when I was building on Ram's website for a while the build would only come up as 3.92 with the LSD. Didn't seem to give you an option for the 3.55 gear. By the time I found a Sport in the color I wanted and the LSD, I didn't care which gears it had I was so sick of looking around.
Might wanna sit down when you get the estimate for the LSD. I'm afraid it might get pricey. We got over 200 inches of snow around these parts last year....the limited slip was a must on my wish list.
Old 11-14-2011, 08:38 PM
WarBaby's Avatar
WarBaby WarBaby is offline
Vehicle: 2014 5.7 Ram 1500 RCSB/2WD
Rep:43
WarBaby is on a distinguished road
Unhappy
I researched this and agree that, until the aftermarket comes up with some options, factory parts are the only way for now. My dealer estimated about $1350 (don't remember exactly) to install factory 4.10 gears with lsd in my `11 RCSB with 3.55 open differential.
For reference, this is my differential:
If it's not broken, fix it till it is!
Old 11-14-2011, 09:18 PM
Rep:6
Originally Posted by WarBaby View Post
. My dealer estimated about $1350 (don't remember exactly) to install factory 4.10 gears with lsd in my `11 RCSB with 3.55 open differential.:
Wow, that's a lot of doh. The dealers would be doing everyone a favor by ordering more of their trucks with LSD. I had a good dealer, who was willing to find the truck with the options I wanted. He even went out of state to get it.
Old 11-14-2011, 09:36 PM
Rep:20
Yeah...$325 option ordered when the truck was built looks like a bargain now. In 2003, I paid $475 for locking diff on my GMC Sierra. This was before the All Star Packages they currently offer on the 2011 Chevy Silverado I was looking at before pulling the trigger on my new Ram.
